Lintels
  • Lintels
    New customer calls & needs a couple lintels welded up. 4" wide tubes onto 3/8"x 11" plates. I show up to meet the truck & I'm surprised at how much there is. All total 130 linear feet in various sizes. Tubes are 3/8" wall 4" x 16" & 4" x 8". Shortest one was 52", longest 16 ft. Luckily he has a skid steer & bought forks for it that arrived the day before. Stitch welded 3" on 12" centers as per plan.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    Are those for brick walls?
      These are going in a concrete block building. They go above all the window & door openings for the block to sit on as they lay it. After I welded them up they got galvanized & delivered to the site. I just finished up today as I had to weld rebar on top sticking up & ties on the sides.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Miller spectrum 875
      RCCS-14
        There must me some pretty serious loads on them.
        Down here its all precast lintels, occasionally power steel which is a 3 sided sheet metal box that acts as a stay in place form and then poured when they pour the cells.
        I guess those are for 12" walls and they are using 4" block on ea side of the lintel?
          it is an odd design for sure.. I have welded up more lintels than I can count. generally, the lintel only has to hold up the triangle of block above the opening, corbeling will carry the weight of the roof if the wall is tall enough.
          I've made up lintels out of 2X3 angle back to back on up to w24X128. I don't design 'em.. I just make what the drawings show...
          Bobcat 225NT
          Cutmaster 52
          Lincoln Weld-Pak 100 buzz box
          Caterpillar TH63
          '07 Kawasaki ZZR600
