Swag Finger Brake Kit for HF Arbor Press
  • Swag Finger Brake Kit for HF Arbor Press
    I finally got around to welding together the Off Road Swag finger brake kit for my Harbor Freight 20 ton arbor press, which my wife gave me a for Christmas. The kit cost $300 including shipping. It was shipped in two of those USPS "If it fits it ships" boxes. All together it weighed about 100 lbs. The heavy duty model can bend 3/16" steel the full width and 5/8" thick steel up to 3" wide.
    1. The first step was pressing the guide pins into the base by the following process:
    • Tack weld
    • Straighten
    • Plug weld
    • Grind flush
    2. Next I welded the guide bushing to the upper guide housing by a similar process:
    • Tack weld
    • Straighten
    • Weld
    Unfortunately the welding process distorted the guide bushing so that they no longer fit over the guide pins so I had to bore both bushings on my milling machine.
    3. I skip welded a piece of angle iron to the formed channel to make the lower die, without difficulty.
    4. The collar to guide the arbor was plated so I put it in some HCL acid to remove the plating. You can see bubbles coming from the plating in the picture. You can purchase HCL acid from Home Depot in the paint department. It is called Muriatic Acid.
    5. To prevent damage to the finger brake a sturdy base is necessary. The cast iron arbor plates that come with the arbor press can't be used because they are brittle and can shatter under load. You can purchase quality arbor plates from Off Road Swag in various sizes but I just used a piece of scrap 1-1/2" x 8"cold rolled steel that I had. I measured the space and cut it to length on my horizontal band saw. Unfortunately it was a little too long so I had to trim it on my mill.
    6. I bent my first piece of 3/16" x 2" steel and it worked fine. The only thing is that the inside radius is about 1/2" due to the fillet in the angle iron used for the lower die.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Here are some additional pictures:
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Here is the last set of pictures:
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        I have the same brake. I didn't finish welding the die. Actually I built it to make a bunch of the same part. Added a ram and pump so i can bend them FAST. When Im done I done with this contract i will probably finish it.
        Performance Aluminum Fabrication
          Another option that someone mentioned was using the Harbor Freight Air over Oil Hydraulic Jack. It is supposed to be a drop in replacement. The air pump attaches to the rear of the cylinder so that you can still use the manual pump and release valve for fine adjustment.
          http://www.harborfreight.com/http-ww...5553-html.html
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            it wasn't a "drop in" on mine. But with a few small mods it works well.
