Why buy it for $1 when I can make it myself for $100.
  • #76
    Looks good man! If you need a couple more big burners, I have two you can have. They’re a little bigger than that one and made for those big wok type cooking things.
    I’ve used my beer making burner to heat my shop in the past. I sat a brake rotor on top to absorb as much heat as possible and then a 12” square piece of .125 thou stainless. On top of that I sat one of those wood stove fans that creates its own electricity from the heat exchange to turn the little fan blade. Works awesome.
    I like the looks of your though. Very nice work.
    • #77
ID:	606444Click image for larger version
      Ryan,
      Seems like great minds think alike.
      Made this wok burner a few years ago to cook for large groups.
      I copied a weed burner design and made it in stainless as the cooker stays outside.
      Also use it for deep frying a turkey and crab boils so it has come in handy.
      Original design did not have the 6" wide band of metal at the top.
      Had to add it as I was getting my chestnuts roasted while cooking.
      • #78
        Latest stay at home project.
        My fire pit tended to smoke too much as I burn junk wood in it.
        I save the seasoned oak and cherry for the fireplace.
        Came across this squirrel cage blower and needed a piece of tubing to direct the air flow.
        The tube came from my neighbor when he replaced his pool ladder.
        Added a piece of stainless flex tubing allow for a bit of adjustment which was not really needed.
        The 2 legs keep the end stable and I was surprised that it does cut down on the smoke. Click image for larger version
ID:	608738Click image for larger version
ID:	608739Click image for larger version
ID:	608740Click image for larger version
        • #79
          Hmmm, that looks like an inducer motor for a furnace. I scrap quite a few of those. Always wondered what some of these parts could be good for.
          • #80
            Behold... The spectacle tree. Could've bought a wooden one for £10.
            Instead spent hours inhaling dust and fumes to make one out of solid mild steel
            • #81
              Then you had to paint it, that was clearly the worst part of the build. I hate painting.
              • #82
                New freezer racks
                After 24 years, my chest freezer went south so I got a new commercial upright one.
                23 cu ft and all stainless interior and exterior.
                But it only came with 3 racks and I needed 5.
                Additional racks were available from the manufacture for $105 each, so I decided to make my own.
                Copied the original racks using 3/8" and 3/16" ss rods.
                Each rack measures 23" x 25" and uses 30 3/16" rods so I used about 125 ft of it.
                Used 5/8-11 ss nuts to space the wires apart and tigged everything together.
                Each rack needed 220 welds so I got a lot of practice.
                Enough space inside to store food for another stay at home order.
ID:	609292Click image for larger version
ID:	609293Click image for larger version
                • #83
                  You could start a new business.... BH’s custom freezer racks!
                  I bet the $105 weren’t nearly as robust. Probably painted carbon steel flimsyass wire too.
                  • #84
                    Yes indeed they are nice and bouncy.
                    The manual says they are epoxy coated steel but it looks like paint to me.
                    Time will tell how well they hold up.
                    Did a rough calculation and found that in theory, I can store 736 TV dinners in it.
                    TV dinner = 1" x 6" x 9" = 54 cu in.
                    1724 cu in /cu ft.
                    1724cu in per cu ft / 54 cu in per dinner = 32 TV dinners/cu ft
                    32 dinners/cu ft x 23 cu ft = 736 dinners.
                    Should hold me for a while.
                    • #85
                      With the hot weather, it was time for some relief.
                      Local pool is closed and I'm too old and out of shape
                      to run thru a lawn sprinkler, so I dug out a Procon pump and motor
                      and mounted it in a Harbor Freight copy of a Pelican case.
                      Added quick connects to make it easier to break down.
                      Found the brass 4 nozzle spray head on ebay for $5.
                      The spray head came from Hong Kong so it had metric or other threads.
                      Ended up brazing it to a stainless tube using silver solder.
                      This gave it a handle to mount it.
                      Put it on a long pole and now I can enjoy the
                      cooling mist while sitting outside with some cold drinks.
                      My neighborhood has a fun run and bike race coming up next month so I might
                      set this up on my lawn in case the participants want to cool off.
ID:	609771Click image for larger version
Name:	Quick connects.jpg
Name:	spray head2.jpg
ID:	609773Click image for larger version
Name:	spray head3.jpg
ID:	609774Click image for larger version
                      • #86
                        Additional spray pattern photos.
                        The nozzles provide a fine mist which saves on water usage
ID:	609777Click image for larger version
                        • #87
Name:	Spoon ball1.jpg
                          Made a ball using spoons. Measures about 20" in diameter.
                          It was made in 2 halves so I could remove the inside form and finish welding.
                          Has a 1/2" x 13 stainless nut inside for attaching a hook or post as shown.
                          The usual suspects say they will check me with a metal detector after I have dinner with them.
                          • #88
                            Originally posted by Burnt hands View Post
                            [ATTACH=JSON]{"data-align":"none","data-size":"medium","data-attachmentid":610380**[/ATTACH]
                            That is really cool, must have taken awhile and many friends dinnerware
                            Richard
                            West coast of Florida
                            • #89
                              ...It was made in 2 halves so I could remove the inside form and finish welding...
                              Aw, darn. You just removed the magic for me!
                              • #90
                                Goodness, how did I miss that yard sprinkler too? How about a spoon ball that is a yard sprinkler?
