Here in Michigan we have had a winter with so much snow that it has been very hard on the snow plowing equipment. Below is a welding project I just did to fix the bracket that mounts under the truck and supports the snow plow, for one of my customers.
Snow Plow Bracket Repair
Smith Oxyacetylene Torch
Miller Dynasty 200DX
Lincoln SP-250 MIG Welder
Lincoln LE 31 MP
Lincoln 210 MP
Clausing/Colchester 15" Lathe
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
BridgeportTags: None
Here are the rest of the pictures...Smith Oxyacetylene Torch
Lincoln LE 31 MP
Lincoln 210 MP
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
Did you replace it with the same thickness or one size bigger? Looks like a fine job. Always nice to see someone cut it out & do it right vs. just globbing it back together.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by MMW View PostDid you replace it with the same thickness or one size bigger? Looks like a fine job. Always nice to see someone cut it out & do it right vs. just globbing it back together.
The plate had been thinned down due to rusting.Smith Oxyacetylene Torch
Lincoln LE 31 MP
Lincoln 210 MP
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
