I am looking for a supplier for a tank head type dome made of 304 stainless that has reasonable prices for a one off order. I want to build a prototype of something and if it works well I'll be order more. I'd like to have an ID of 16" and a dome height of around 4". I have been through most of the products at toledo metal spinning and haven't found anything off the shelf that will work. They could probably make one for me but that could add up quick. Thanks.
304 SS Dome
Tank heads have always been expensive especially in low quantities.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
elvis,
Here is a sculpture I made which measures 18" in diameter.
Used a wok for the form which cost me $19 at my local Asian grocery store.
You mention that you can use 16 to 18 gauge material.
Granted it's not stainless which is what you need but maybe
you can mock up a prototype cheaper with one of these.
They come in sizes from 12" to 30".
I may fill this one with concrete and use it as a form to hammer out a sheet of .040" stainless to make a stainless wok.
Looked at ASME pressure vessel ends in stainless to make a rust proof wok but gave up when I saw the prices.
Good luck with your project.Miller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, large first aid kit, etc.
After pricing stuff out I might just buy a conical fermenter. I can buy it for $650 or build it for a little less. It sounds like a fun project but too expensive when you add my time into the mix. Maybe another time.MillerMatic 251
Maxstar 150 STH
Cutmaster 42
Victor Journeyman OA
Nathan-
Normally I would say yes but I don't think I could get 16ga 304 pipe in a 16" or 18" diameter
Burnt-
I could probably make a mold and just use a 20ton press and make my own domes. Interesting idea.Last edited by elvis; 01-29-2014, 12:08 PM.MillerMatic 251
Maxstar 150 STH
Cutmaster 42
elvis,
How about this?
It measures 16" in diameter but it is very thin 300 series stainless.
Another drawback is it's flat bottom.
It was hiding in my kitchen drawer.
Use it for big batches of pancake batter.Miller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, large first aid kit, etc.
Might be an odd aproach.... BUT...
How about cutting the bottom out of a beer keg..??
Stainless steel... Domed.... Usually a $20 deposit at most distributors...
you would have to buy and drink the beer though.....
