Trailer repair
  • Trailer repair
    Had to go pick up an aluminum ramp to weld today. While I was there the driver/owner asked me about "putting a little weld on his trailer to make it stronger". "Maybe a brace too?" Holy crap! I told him no way am I going to just try to do a patch job. It needs to be fixed right as it is dangerous & will keep getting worse. I am supposed to come up with a price when I drop off the ramp. He was more worried about the deck being buckled & not flat then he was about the structure.
ID:	532531 Click image for larger version
ID:	532532 Click image for larger version
ID:	532533 Click image for larger version
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    Wow. Overloaded much? I'd like to know how that turns out. That is a lot of re-engineering to get that back up and rolling safely.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
      Looks like it will need new uprights.& a section of decking.
      Keep us updated. Looks like a good project.
      Miller Bobcat 225NT onan
      Millermatic 211
      Spoolmate 100
      (Retapped to fit regular mig tips)
      Work better & less parts to stock.
      Miller 130xp
      T/A Dragster 85 (portability 11 pounds)
      Oxygen/Acetylene torch set 50'
      2. 4-1/2" grinders
      1. 9" grinder
      14" Makita chop saw
      1/2" Aircat impact gun 900#
        Thats a jackpot job!
        I agree with everyone here, this could be a very nice repair project to get the trailer back up to snuff. I guess it depends on if the owner will spend the money to do it properly. There are a lot of shady acres types that dont or are just too cheap to do it.
        As in another one of the replies , there is a certain amount of engineering , and liability. That unit would probly have to be inspected by the DOT? the sad thing is if they dont want to do it right you would be better to take out the torch and butcher it up for the good off everybody else on the road!
        I have a welding addiction
        ...the only stupid question is the one you didn't ask
          Overloaded or was it in a collision?
          The bends look like the deck tried to keep going when the tongue didn't want to.
          Syncrowave 250DX
          Invison 354MP
          XR Control and 30A
          Airco MED20 feeder
          Thermal Dynamics Cutmaster 81
          Smith O/A rig
            He told me that there was a car on the front deck & a large fork truck drove on the trailer to pick up the car. When the fork truck picked up the car that put all the weight about 18-24" behind the drop which just bent it. He did not have the landing gear down which if he did most likely would have been o/k.
            These trailers are built very lightweight. The upright tubes are 4x4x3/16" tube. My initial thoughts are cutting the lower deck loose from the uprights, with it disconnected & the landing gear down then carefully push down on the front of the top deck to get it straight. After it is straight then I will decide on the next move, either replace or repair. But at this point I'm just trying to come up with a number.
            Yes I know this is a big liability & needs to be done correctly.
            MM250
            Trailblazer 250g
            22a feeder
            Lincoln ac/dc 225
            MM200 black face
            Miller spectrum 875
            RCCS-14
              Good luck with watever you decide to do.
              Lincoln A/C 225
              Everlast PA200
                Trailer repair
                Good luck and make sure your insurance is up to date. I fight with my insurance all the time about jobs like this.
                  Id recommend replacing the 4x4s they been compromise.
                  Millermatic 211
                  Spoolmate 100
                  Miller 130xp
                  2. 4-1/2" grinders
                  1. 9" grinder
                  14" Makita chop saw
                    I would cut out all of the bad and start over. I also would make the gussets larger and run it down farther to the bottom channel like it isn't in pic 2. Also not to a point at the bottom leave some more meat...Bob
                      trailer material...
                      All of thoose 3 car car haulers are built extremely light, that trailer is likely 1/8 or 3/16 tube, they are not built like a normally fifthwheel or gooseneck, very light braced construction, i have friends who pull these trailers, with 3 cars, trailer, and truck, they gross around 33k. Thats on an f350! Most of thoose trailers do not take heavy static loads well, normally the floor falls out!
                      Kevin
                      Lincoln ranger 305g x2
                      Ln25
                      Miller spectrum 625
                      Miller 30a spoolgun
                      Wc115a
                      Lincoln 210mp
                      F550 imt service truck
                        Good luck, Looks like a fun repair, Just go a little heavier and I bet you'll be fine.
                        At a quick glance its a $ 5000.00 repair, Maybe as hi as 7,000.00
                          Unfortunately I won't be doing this trailer. I dropped off his ramp today & we discussed the trailer. He doesn't want to pay to have it fixed & is looking for a 15 ton trailer (this ones 10 ton). He's going to run it as is for now.
                          MM250
                          Trailblazer 250g
                          22a feeder
                          Lincoln ac/dc 225
                          MM200 black face
                          Miller spectrum 875
                          RCCS-14
                            That thing wont make it pass dot.
                            Make him an offer fix it / paint & flip it.
                            Millermatic 211
                            Spoolmate 100
                            Miller 130xp
                            2. 4-1/2" grinders
                            1. 9" grinder
                            14" Makita chop saw
                              The owner just called me this morning. He got a warning from DOT to get it fixed. Looks like I'll get to repair it after all. He said he'll drop it off in about 10 days.
                              Makes me happy as it's been real slow as of late.
                              MM250
                              Trailblazer 250g
                              22a feeder
                              Lincoln ac/dc 225
                              MM200 black face
                              Miller spectrum 875
                              RCCS-14
