Sealing Steel Welds on Stainless Steel art projects...
  • Sealing Steel Welds on Stainless Steel art projects...
    What would you use to 'seal' steel welds on stainless steel so that it slows or stops them from rusting? I am using steel wire on my stainless steel art projects.. I have noticed it takes no time at all for the welds to show rust and I want to slow or stop it with a sealer of some type.. any suggestions? (can't afford stainless wire just yet)....
    http://www.flickr.com/photos/2319618...n/photostream/
    Steel wire?? Why aren't you using SS wire?
    CG
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
      CG
      Nope.. I just started out about a month ago and I just had steel wire for the mig.. stainless was alot of money for me to invest in when I didn't know if I would like or even be good at what I am doing.
      I had talked to a few ppl that said the steel wire would be ok, but that I should seal to help them from rusting so quickly..
        To answer your question you'll need to prep the surface by scuffing & cleaning. Then apply a clearcoat or paint.
        But you should be using stainless wire & tri mix gas unless you want rust or discoloration.
        MM250
        Trailblazer 250g
        22a feeder
        Lincoln ac/dc 225
        MM200 black face
        Lown 1/8x 36" power roller
        Arco roto-phase model M
        Vectrax 7x12 band saw
        Miller spectrum 875
        30a spoolgun w/wc-24
        RCCS-14
          Crud.... I have argon/co2 mix, I would have to switch that out too??? ****..
            Argon/co2 will work but it is not the right gas & again you will be losing some corrosion resistance.
            MM250
            Trailblazer 250g
            22a feeder
            Lincoln ac/dc 225
            MM200 black face
            Miller spectrum 875
            RCCS-14
              oh well.. it is garden art after all.. rust will probably enhance the look..
                Spray with deft or other clear lacquer. After paint prep of course.
                  I bought a roll of stainless wire from Airgas which is formulated to use with 75/25(so they say).Have not tried it yet.
                  2- XMT's 350 cc/cv
                  1- Blue star 185
                  1- BOBCAT 250
                  1- TRAILBLAZER 302
                  1- MILLER DVI
                  2- PASSPORT PLUS
                  1- DYNASTY 200 DX
                  1- DYNASTY 280 DX
                  1- MAXSTAR 150 STL
                  1- HF-251 BOX
                  1- S-74D
                  1- S-75DXA
                  2- 12-RC SUITCASES
                  1- 8-VS SUITCASE
                  2- 30 A SPOOLGUNS
                    Airgas SS wire formulated for 75/25?
                    Please give us the name/designation of this wire, since
                    this assertion by Airgas flies in the face of the metallurgy/chemistry
                    of SS welding with high CO2 content gas.
                    I'm not bashing-you, I'm very curious to know more particulars about
                    this claim.
                    From my own experience-this wouldn't be the first time that Airgas has touted things that just ain't-so.
                      Like the Aceteyne shortage/price gouging.
                      I did see a new mig welder and the door sticker read for welding SS use 75/25 gas. But i don't remember the maker only that it had a blue case...Bob
                        Is it by any chance gas shielded stainless flux core? Take a look at the Lincoln Stainless Steel welding guide as well as their gas shielded stainless flux core wires.---Meltedmetal
                        ---Meltedmetal
                          Don't know if you've read into welding stainless much, but you might want to invest in some sort of respirator / fume extraction system if your going to mess with welding stainless steel much. It puts off nasty fumes containing Hexavalent chromium which is not something you want to be breathing in.
                            I checked the box, it is flux cored. Unibraze E 308L T.1
                            I bought it a while back to try it out but haven't yet.
                            2- XMT's 350 cc/cv
                            1- Blue star 185
                            1- BOBCAT 250
                            1- TRAILBLAZER 302
                            1- MILLER DVI
                            2- PASSPORT PLUS
                            1- DYNASTY 200 DX
                            1- DYNASTY 280 DX
                            1- MAXSTAR 150 STL
                            1- HF-251 BOX
                            1- S-74D
                            1- S-75DXA
                            2- 12-RC SUITCASES
                            1- 8-VS SUITCASE
                            2- 30 A SPOOLGUNS
                              jrasche2003,
                              I have .035 and .045 stainless solid wire on 12" spools and as I only TIG,
                              I can cut some for you to play with.
                              PM me and I will send it to you.
                              Don't know it it will work with your gas mix but the price is right - free.
