aluminum welding table HEAVY DUTY
  • aluminum welding table HEAVY DUTY
    Hi, I started making a table out of 2"x6"x1/8" box aluminum. Im not sure what I should use as a top. What would a table like this be worth? And how can I make it as functional as possible? Thanks. Pics below.
    Well, that would depend on its purpose.
    2- XMT's 350 cc/cv
    1- Blue star 185
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    2- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- DYNASTY 280 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74D
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
      well thats what i need advice with. I am a welder, but never saw a all aluminum welding table. If I should throw 1/2" aluminum plate on top let me know........what would you do with this table?
        Use a steel top... Spatter will kill you if you use aluminum.
        My own shop since 1981
        Cya Frank
          really? i see what your saying, but it seems such a shame to throw steel on top of this alum table.
            Cover it with steel and comeback with a flapper disc and polish the crap outta it. Frank is right,splatter will ruin it and really break your heart.
              personally, I would have never wasted that aluminum on legs for a welding table.
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              Miller Syncrowave 200 Tig
              2-O/A outfits
              Jet Lathe and Mill
              Jet 7x12 horz/vert band saw
              DeWalt Multi Cutter metal saw
              Century 50 Amp Plasma Cutter
              Propane Forge
              60" X 60" router/plasma table
                An aluminum table top would be good for small tig work or assembly work that needs to be handled carefully. Aluminum is soft so it would not mar/scratch the pcs. as easily. As far as a normal welding table I don't think it would have much use. To soft, will gouge easily, unable to tack pcs./fixtures to easily, expands/contracts at a different rate than steel.
                #1) top material -- If used for general welding use a steel top.
                #2) worth? -- As a welding table not much imo. Used welding tables don't command much money.
                #3) functional -- Maybe polish it & put a nice wood top on it to use as a desk?
                MM250
                Trailblazer 250g
                22a feeder
                Lincoln ac/dc 225
                MM200 black face
                Lown 1/8x 36" power roller
                Arco roto-phase model M
                Vectrax 7x12 band saw
                Miller spectrum 875
                30a spoolgun w/wc-24
                RCCS-14
                  Yeah we had the material laying around. Still not sure what to do with it.....hmmmmm.
                  Anymore ideas? Like I said if you had this table what would you do with it?
                    If it were mine I would finish it out in alum and put my ole Tombstone on it with lead hangers and maybe a bench grinder or vise on it. Lots of crap hangers and a shelf or two for more crap.
                      What about stainless on top?
                        Stainless if fine for a potting bench but will suck for a welding table. The spatter from steel will rust...Bob
                          I used a big SS top once, that thing would hold heat forever. It was on another table top so I put some short legs under it, still held the heat too long IMO.
