Hi, I wonder how they made the collars for this load able dumbell Handel.
collars for dumbell
Wow...
Never have I seen something so simple be treated like it needs to be sent to NASA for analysis...!
It is punched out of flat stock...like plate or bar.
You can see the die marks on the edge...or punch marks, however you decide which one leaves them.MillerMatic 211 Auto-set w/MVP
Just For Home Projects.
The discs are burned from plate. Either oxy/acet or plasma. My guess the ones in the pic are oxy/acet. With a burning machine doing a large qty. the cost would be cheap. To make just a few it wouldn't be profitable for resale.
Today plasma would most likely be used.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by Bossman2000 View PostSo they just plasma cut the holes out of a 1/2 inch 25mm plate?MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
I would also say flame or plasma cut. Your later pictures show more detail. I sometimes lay a tape measure extended beside the part I am photographing to give a size reference in the photo. I find it helps when I refer to it later. I'm guessing you want to make some of these? Depending on how you are equipped and how many you want to make you could also machine them from solid bar or cut them from heavy walled tubing if you can find it in the right dimensions at a reasonable price. Plasma does do an acceptable job though.---Meltedmetal---Meltedmetal
Cost effectiveness would depend on the equipment available and the number required. If I understand the Bossman, the center hole is 2 inches. They appear to be taller than they are thick and he says they are 1/2 thick so that would make the OD somewhere over 3 inches.
Meltedmetal
And my eyesight isn't what it used to be but I see torch marks. Haha. Mm---Meltedmetal
