Smoker Build
  • Smoker Build
    I had a guy come to me to build a heavy duty reverse flow smoker. I figured I should put a build thread together. Should have it finished Sunday or Monday. I had been thinking about building myself one so it was good timing. I picked up a 42" piece of pipe for my personal smoker and I haven't had a chance to build it yet.
    Build specs:
    2'x3' Schd 20 pipe. 3/8" end caps and firebox. 5/16" round stock for the food grate and 2 levels of cooking space.
    Lessons learned so far:
    -He wanted to supply most of the odds and ends and brought me a 3' length of FBE pipe. DO NOT start with this. It is a huge pain to remove the epoxy coat. Took me several hours to do so. It was still cheaper for the customer rather than buying clean pipe, but that was his call.
    -I ended up using some laser cut 1/4" hinge tabs that pull the lid away from the cook chamber as you lift it. This is a nice feature over using barrel hinges. I would definitely use these again. They have a 3/8" hole for a bolt but I am going to use a piece of hot rolled round as a "hinge pin" instead, mostly for personal preference.
    -I CNC plasma cut the end caps and firebox pieces and this was well worth it. Faster than hand cutting and easier to piece together. Also, for the firebox I designed it so that each corner was a v-groove type deal and the welds have full penetration in one pass. It also gives the corner a 45* angle and I think it looks nice.
    Ok, enough words, on to pictures.
Name:	2013-03-05 13.27.24.jpg
ID:	532227Click image for larger version
Name:	2013-03-06 12.24.50.jpg
ID:	532228Click image for larger version
Name:	2013-03-06 12.25.09.jpg
ID:	532229Click image for larger version
Name:	2013-03-06 14.49.52.jpg
ID:	532230Click image for larger version
Name:	2013-04-13 09.37.51.jpg
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
Name:	2013-04-13 10.20.39.jpg
    I'll post some more pictures tomorrow evening.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
      Its pictures like these that makes a wanna be like me wonder “WTF is the use of trying to get into this hobby”. You have some fantastic talent! I love seeing what the pros can do .
      WS
        WS
        Whopper the only way you are ever going to be like these craftsman is buy doing it . the more stuff you do the more you will learn . don't be intimidated by this stuff there is a wealth of information on these sites and there are allot of guys willing to help .welding and fabrication is just like any other trade some guys are better than others and some guys are just gifted and some guys just don't give a s**t .this Elvis guy he's got it figured out . by the way Elvis awesome fab work keep the pics coming . Chris
          WS
          Whopper,
          Everyone on this board started somewhere. It just takes practice. It is true that some people are talented at it and some people have to work their a$$ off to get good. It just boils down to how much you want it?
          Thanks for the kind words.
          MillerMatic 251
          Maxstar 150 STH
          Cutmaster 42
            These are the only pictures from today. Got the firebox fully welded on and the baffle stitched into place with the drain pipe. I spent most of the day installing frame stiffeners on a unibody jeep.
            Tomorrow will be legs and smokestack and that should pretty much wrap it up. This thing is getting extremely heavy!
            MillerMatic 251
            Maxstar 150 STH
            Cutmaster 42
              Looking nice Elvis. What made you decide to put the fire box under instead of beside the grill? It is a neat look I have never seen before. I wonder if it is more effective at heating since the fire box will be directly under the grill instead of just the heat from the smoke beside it.
              I'm curious how you plan to empty the ashes from the fire box. It looks like the door has a lip all the way around, and from pictures it looks like that is the only door. So would a shop vac be used since you couldn't sweep them out over that lip? The one I made long ago had a door at the bottom part of the box to sweep out the coals.
              Keep up the pictures coming.
                It is what the customer wanted. It seems to make sense. I do admit that I did not account for the ash removal. That was not a critical issue when he described what he wanted. Probably a shop vac.
                Anyway, on to the updated pictures. Made a little progress today. Tomorrow it will get wheels and some door trim. Perhaps a smoke stack.
                MillerMatic 251
                Maxstar 150 STH
                Cutmaster 42
                  I'm not a smoker of either description so excuse my ignorance please. I do burn wood though and one of my stoves has the firing/cleanout door about 12 inches above the floor of the firebox. I made myself a small shovel and just push the ashes to the back of the firebox and shovel them out and into my ash bucket. It works well. I assume you burn your fuel directly on the floor of the firebox and not on a grate? Nice construction by the way.
                  Meltedmetal
                  ---Meltedmetal
                    Is there going to be a shelf under the door for the cooker to set stuff on that's going in to or out of the cooker. If not, it might be worth thinking about. It could be made removable for when it's not needed.
                      Melted-
                      The plan is to try it on the floor first and if it doesn't burn well to build a rack out of 3/4 round stock.
                      Bistineau-
                      The guy has a food grade stain less table that is about the same height. He requested that a table be omitted at this time.
                      Fwiw, the handle on the door will be a piece of turned Arizona cypress. Should look nice. Thanks for the comments guys, this has been a fun build. I have learned that 3/8 is a bit thick and if I do it again I'll build it out of 1/4".
                      MillerMatic 251
                      Maxstar 150 STH
                      Cutmaster 42
                        MillerMatic 251
                        Maxstar 150 STH
                        Cutmaster 42
                          MillerMatic 251
                          Maxstar 150 STH
                          Cutmaster 42
                            That's badass!
                            Millermatic 210
                            Syncrowave 200
                            Spectrum 625 X-treme
                            Hobart Champion 16 W/
                            Miller 8VS Suitcase
                            Miller 3035 Spool Gun
                            Tons of Tools
                            Microwave
                            Laptop and Printer
                            Speakers in the Back for all to hear Sirius Radio!
                              That's a really nice build. Again excuse my ignorance of smoking but isn't that a lot of iron to heat up just to cook something? I'm thinking of fuel efficiency or is that not a consideration once the party's started? On the other hand it should stay hot for quite awhile with not much fuel to sustain it I suppose.-Meltedmetal
                              ---Meltedmetal
