That square hollow section begged to be trued by the new lathe chuck. So I turned the revs down to 160rpm and feed rate was 0.05mm per pass. The tube was cut by a aluminium drop saw so only need 4 passes per end.
Using a dial indicator was pretty confusing as I could not get it any closer than .05mm. Then I saw what was happening. The tube walls were deflecting inwards from the force of the chuck jaws.
Oh well it was centred.
worked better than expected.
Ji
Ji
