I have used a few different methods to notch tube over the years. Some that work great and are worth the time to set up others not so much. Today I needed to notch a 40mm diametre tube to fit to a 100mm diametre tube at 90 degrees. I noticed this free download program that has been around a while and thought I would give it a go "Tubemitre". I punched in the data and printed out the result. Used sticky tape to fix the paper template to the tube and with the aid of an air hacksaw cut away the excess in a few minutes. The result without any sanding is just about good enough to start welding.
Pretty cool.
Ji
Pretty cool.
Ji
