home made purge block ideas
  • home made purge block ideas
    guys,
    i searched and couldnt find many pics of any purge blocks on here.
    i will be practicing tig welding on stainless sheet metal and want to do it the correct way.
    i like to make my own tools when possible, and would like you to share any of your pics and ideas on how you made your purge blocks, or where did you buy them ?
    thanks in advance for any help you can offer.
    Syncrowave® 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    i seen some a few years ago in a magazine. i think they were a thin box shape made out of copper with drilled holes throughout...and a fitting for the argon line..
    does this sound correct ?
    thanks
    Syncrowave® 200
      Here is an article by Miller on tig welding titanium but the techniques are applicable to stainless also.
      http://www.millerwelds.com/resources...tanium-welding
        The pieces in the second photo look a lot like the ones I've made for myself.
        Dynasty 300DX
        MM350P
        Hobart Handler 120
        Smith LW7, MW1, AW1
        Smith AR/He Mixer
          FABMAN,
          Here are 2 trailing shields I made.
          Quick and cheap to make for a one time job.
          Used fine stainless mesh for the gas diffuser and .035" stainless for the back. SS tubing is 1/4" diam.
          Next version will use stainless perforated metal with .033" diam holes.
            FABMAN,
            I like the idea of using fine mesh ... thanks.
            Dynasty 300DX
            MM350P
            Hobart Handler 120
            Smith LW7, MW1, AW1
            Smith AR/He Mixer
