cutting expanded?
  • cutting expanded?
    What is the fastest and easiest way to cut expanded steel?Thanks.
    Stickwelds
    millermatic 251
    thunderbolt xl
    hypertherm powermax 380
    jet bandsaw
    delta chopsaw
    The fastest and easiest is a shear.
    Since I don't own one, I use my plasma with a straight edge guide.
      Ditto. I'm so po', I didn't even think of the shear. I use plasma. This is where you need a GOOD, modern plasma, though, because the old-style and even the new cheap ones don't have the automatically relighting pilot arc.
        And if you're even poorer you can use an angle grinder
        Fire, Fire!!!... Oh wait, that's my torch
        Lincoln PT-225 TIG
        Lincoln 175 MIG
          I've used a sawzall with decent results, too. You don't even need the straightedge because the expanded diamonds will recenter the blade for you for each little cut.
            Circular saw with abrasive wheel has worked for me...
            Syncrowave 250DX
            Millermatic 250X
            Hypertherm PowerMax 1100
              i just use a grinder on a straight line
              Eric
              "Why go around the mudhole when you can go through it"
              Miller Bobcat 250
              Miller Syncrowave 200
              Lincoln Pro-Core 100
                I have even used a jigsaw with a metal blade for tight places and it worked good
                but always wear your safty goggles.......those metal bits get everywhere .
                  What about just using your stick welder with a E6011 rod - quick and easy
                    Hey richcharles what rod size should I use?I have some 60/11 they are 3/32 and 1/8.
                    Stickwelds
                    millermatic 251
                    thunderbolt xl
                    jet bandsaw
                    delta chopsaw
                      Go with the 1/8 rod at 90-100 amps.
                      Hope that helps
                      Charles
                        14" gas powered cut-off saw. Keep a steady hand.
                        Just kidding. I usually go the skill saw with abrasive disc route.
                        The difference between No One. and No. One is where you put the period. John Force
