Press brake - Opinions
  • Press brake - Opinions
    I bought a HF 20T press. My main use for it will be bending flatstock. My standard most common size will be 4x3/8" flatstock @ 90deg. I have attached a drawing of my plan. It is designed with what I have here in my shop.
    Any ideas/modifications will be appreciated.Click image for larger version
Name:	Press brake.jpg
    Looks like it will work. You might want to make your top punch tighter than 90 degrees like 80 something. Mine is 42 degrees on a side...Bob
      Bob is correct, you want your top & bottom dies tighter than 90 degrees or you will have trouble getting your pcs. to 90.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Lown 1/8x 36" power roller
      Arco roto-phase model M
      Vectrax 7x12 band saw
      Miller spectrum 875
      30a spoolgun w/wc-24
      RCCS-14
        So both the top and bottom @ 80 deg?
          No just the top. The bottom can be 90...Bob
            Okay, so just the top @ 80 deg or so. Bottom can be 90deg....
            Does the punch have to be hardened? If so, what is the proper process for it?
              Thats up to you. How many parts you going to make? A zillion then yes. If the bottom center wears just regrind or recut it to suit. Just my thoughts...Bob
                thanks bob,
                Over the course of a year, ill probably bend 100-200 pieces. possibly more if it works as well as it seems like it should.
                  For air bending which is what you plan on doing the bottom should be less than 90. The 4 way die on the Cincinnati I used to run was 82*. The top should be sharper than 90 also. This lets you over bend slightly to compensate for spring back.
                  I can't see how thick a plate your top die will be but I would use 1".
                  MM250
                  Trailblazer 250g
                  22a feeder
                  Lincoln ac/dc 225
                  MM200 black face
                  Miller spectrum 875
                  RCCS-14
                    I used angle for the top and bottom on my iron worker brake and it over bends a 90 every time if your not careful.
                      Here are some pics I took a bit ago
                        Another
                          AnotherAnother
                            The press modified. A little ugly, but works fairly well
                              This is what its bent for. Its the strap for semi trailer s
