Hydraulics
  • Hydraulics
    So, where do you guys go to source hydraulic parts? I'm designing an electric over hydraulic tube bender running a 15ton ram. Plan to mostly bend .120 x 1.75" dom tubing. I have my specs figured out (thanks to sft) and now I just need to find the parts and buy them as money allows. I was thinking surpluscenter for the ram (4"x18"x1.5") and valve (2500psi), but what about the motor and pump? I figured going local for the hoses. I would love to find a pump that would run 2000psi minimum and .15ci/rev and run on a 115v/20amp circuit, but i can certainly handle running the pump on 230v. I only have one 230v circuit available, so I get tired of swapping the plugs for each machine out of the receptacle. I hope this all makes sense to someone...
    Also, I am using a spreadsheet for all these calculations. I plan to build a reservoir. I have a sheet of 14ga just sitting around right now. I only need 1/2 of it or less to build a tongue toolbox for a trailer.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Hydraulics
    Ok Elvis this is kind of difficult because this is going to be a location thing for you. Your going to need a couple of things. Ok for me I live near Detroit MI so I go to a couple different shops one for cylinders and hoses and the other sells and repairs motors, pumps, and valves. When I need something they walk me through it with all the parts and accessories I need for hydraulic applications. I recommend finding heavy equipment places around you then ask them where they get their hydronic motors rebuilt and go from there or search for places near you. I will get the number at work for my place and can give it to you or make some calls for you. It should be that difficult.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
      I get most of mine from surplus center. I have also purchased parts from www.daltonhydraulic.com
        Thanks guys. I'll check out your suggestions
        MillerMatic 251
        Maxstar 150 STH
        Cutmaster 42
          We use http://www.baileynet.com/ great customer service and prices
            If you have a compressor in your shop, have you considered air over hydraulic? Way cheaper than buying a hydro pump and setup, and works just as well.
            Ed
              That is what I have now. I'm looking for faster cycle times. For an 8-ton air/hyd 20" stroke ram to go full cycle takes almost 2 minutes. I'm looking to cut that down to 40 seconds or so. Also, When I build a shop press I can push a little more force out (40ton) and also run the ram on a trolly so I'm not stuck in only one position.
              MillerMatic 251
              Maxstar 150 STH
              Cutmaster 42
                I converted my bender over to hydraulics a couple of years ago. I purchased my ram and pump unit from Northern Tool, but Surplus Center does have the same pump unit and ram a few bucks cheaper.
                My pump is a 1hp 110/220 vac, 2500# Haldex unit.
                The ram is (3"x24"x1-1/2") and is 2 stage.
                Bending a 2" x .120" tube it takes 24 seconds to make a 90* bend and can go 114* on a single stroke without repenning. From full extention to full retraction takes 16 seconds.
                I use a 4-way valve.
                I've been really pleased with how this unit has worked.
                Here's a few photos of my bender.
Name:	Hydraulic Tubing Bender 003.JPG
ID:	515458Click image for larger version
Name:	Hydraulic Tubing Bender 004.JPG
ID:	515459Click image for larger version
Name:	Hydraulic Tubing Bender 002.JPG
ID:	515460Click image for larger version
Name:	Hydraulic Tubing Bender 001.JPG
                Bill
                Miller Dialarc 250 AC/DC
                Miller 251
                Thermodynamics Plasma arc
                Benard "Center Fire" wirefeed gun
                Miller alum. spool gun
                Tweco Tig torch
                Victor O/A torches
                B&D Wildcat 9" grinder
                DeWalt 10 amp 4-1/2" grinders
                7"x12" bandsaw
                A shop that's always going to be to small.
