Good Day Fellow
I am a quality control Engineer supervising the construction of an API-650 5000 M3 HFO tank currently , and I am doing this for the first time , and I can make use of the advice that I can get on how :
1) to give a numbering system for ( welds , Welding operators ) and how to write it down on the tank itself .
2) how often should I check welders' work ( should I check it after each run ,,,,or maybe after they are done with the whole seam )
3) Need to know the operation sequence for welding , where to start , and how to syncronize welders' work
4) Is there any brief paper of the code ( API-650 ) limits for rejection and acceptance , as each time am looking for one , i had to go through a lot of chapters and sections , so I would really appreciate it if one of you guys have all the limitations written briefly in one place
5) any advice on the most common NDT test that are usually taken on tanks
PS : I can send you pics that i took for the project for better explanations
Appreciate all other help and advice
