I will be building a trailer to haul my 3 hogs on, i have many ideas on how to plan this thing out, any one know of where to find plans, i never use plans on stuff like this but with tounge weight, ect, plans could come in handy, also any one have any tips on how they would tackle this. I have built a few trailers in the past, with good succes, i am curious as to what you guys have to say. Thanks kevin
Building a motorcycle trailer
I'm also curious. I'd like to build a trailer to put my TB302 on. Even though I don't need dual axles, I want them for a better ride. I also want shocks on it to smooth it out even further.Lincoln Vantage 400
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic 350P Aluminum
Millermatic® 252
Syncrowave 351
Lincoln LN-25 Pro
Multimatic™ 200
XR-Aluma Pro Gun
Diversion™ 180
Spectrum® 625 X-TREME™
Thermal Dynamics® Cutmaster® 52
Victor Oxy/Acetylene Set
yea, i gotta bone up on where to buy all this stuff, i know tractor supply sells axles, ect. but i know that there are companies who specialize in selling trailer parts, any clue where to start, i can google it, but i like to get info from people who have hands on experience. thanks
Originally posted by kevin View Postyea, i gotta bone up on where to buy all this stuff, i know tractor supply sells axles, ect. but i know that there are companies who specialize in selling trailer parts, any clue where to start, i can google it, but i like to get info from people who have hands on experience. thanksLincoln Vantage 400
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
Lincoln LN-25 Pro
Multimatic™ 200
XR-Aluma Pro Gun
Diversion™ 180
I'm a Rigid hitch dealer, Call them to find out where their closest dealer is.
When building a motorcycle trailer ( There will never be enouph tie downs )
If your going to build a fold down ramp dont forget to factor the ramp in on the tongue weight and make sure 10%- 15% of the trailer gross weight is on the tongue with the bikes on it.
So lets say the trailer weighs 900 lbs. and each bike weighs 800 lbs. on a single axle trailer that is 3300lbs total.
If your tonge weight is 330 lbs it will tow like a dream.
good point, is there any formula,s for where to place the axle, i was thinking of using only one axle, would two axles be a better set up, the trailer will not be very long, most likely about teen feet, for the deck, the bikes measure around 8 feet long, thanks, kevin
Help
Kevin,
With you being on the east coast, check out Weaver Distributing, www.weaverd.com . They have very competitive prices and free shipping. I use them all the time.
Look at championtrailers.com They have a basic trailer design on their site. Figure out wht size deck you need and build it. Put it on the ground on top of a piece of pipe, park all three bikes on it where they go and roll it forward and backward until you find the balance point. Mark that as the center, then measure back 10% and place the center of the axle there.
KVALL, a dual axle won't give you a smoother ride than a single axle with only a welder on top of it. It will bounce around a lot. A single axle (#3500) will bounce around a well unless you put on a lighter spring.
Originally posted by walker View PostLook at championtrailers.com They have a basic trailer design on their site. Figure out wht size deck you need and build it. Put it on the ground on top of a piece of pipe, park all three bikes on it where they go and roll it forward and backward until you find the balance point. Mark that as the center, then measure back 10% and place the center of the axle there.
Then I want to build locking cabinets and drawers on the trailer. I think after I fill those up with cables, clamps, cylinders and other tools I could be looking at another 300lbs. Then there's the weight of the trailer with cabinets and drawers added.
This won't be a simple light trailer just big enough to hold a welder. It would be a heavy-duty (overkill) trailer. It would have some weight on it.
Do you still think dual axles wouldn't be beneficial?Lincoln Vantage 400
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
Lincoln LN-25 Pro
Multimatic™ 200
XR-Aluma Pro Gun
Diversion™ 180
No, I think with all that there would be enough to make the springs start to work. If I was to rework mine I think I would pull the spring packs apart and put in the poly spring liner (available at street rod parts retailers). I would also think about greasable spring eye bushings. Those tend to fail a lot quicker than I would like. Since you are building new consider building the deck and then building a removable skid for the welder. Also make the skid so it stood off the deck 4-6" or so, this allows for materials to slide under.
Originally posted by walker View PostNo, I think with all that there would be enough to make the springs start to work. If I was to rework mine I think I would pull the spring packs apart and put in the poly spring liner (available at street rod parts retailers). I would also think about greasable spring eye bushings. Those tend to fail a lot quicker than I would like. Since you are building new consider building the deck and then building a removable skid for the welder. Also make the skid so it stood off the deck 4-6" or so, this allows for materials to slide under.Lincoln Vantage 400
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
Lincoln LN-25 Pro
Multimatic™ 200
XR-Aluma Pro Gun
Diversion™ 180
A flatbed trailer, that might have multiple different loads on it, I prefer dual axles, you have a larger sweet spot to get the center of gravity in.
A single-purpose work trailer, where weight won't vary more than a few pounds fore and aft, is better with a single axle. Easier to hook up and unhook, and move and turn manually if necessary to place it where you want. If you have to pick it up with a forklift, and set it somewhere or hold it 20' above ground, easy to straddle the single axle with the forks, not so much with a dual axle setup.
Unless you are trying to jump corn furrows at 30 mph, I wouldn't worry about the bouncing. My experience is that both portable welders and Harleys are designed to be PORTABLE, you will probably beat your brains out on the truck cab roof before the welder or bike quits.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
I would look around for used trailers first
For either of the 2 trailer projects being talked about in this thread
Kvwall, I would suggest starting a new thread- talking about 2 differently functioning trailers in one thread is gonna get confooosing.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by kevin View PostI will be building a trailer to haul my 3 hogs on, i have many ideas on how to plan this thing out, any one know of where to find plans, i never use plans on stuff like this but with tounge weight, ect, plans could come in handy, also any one have any tips on how they would tackle this. I have built a few trailers in the past, with good succes, i am curious as to what you guys have to say. Thanks kevin
You ride the Bikes so probably not new to you but those bikes like to scrape bottom going up and down ramps- just a reminder when building the deck height and ramp length.
Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Ed's got a good point here,,,,, it is much easier and cheaper to take an existing trailer, and move the load around, until it's right, and bolt it down.
Just in case anybody's interested, I've been buying all my trailer axles and parts from Southwest Wheel the last few years. http://www.trailerpart.com/
No free shipping, as far as I know, but more important to me is the correct part, in a timely fashion.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
