I have a similar question, I'm getting ready to cut into a large Butane tank to make a BBQ pit on a trailer. My problem is I've never cut into a butane take before and dont want to blow up my shop, me included!! Any ideas how to clear the fumes from the tank prior to hitting it with the Torch/Plasma cutter?
Cutting
I agree this is a life or death kind of thing.
If you miunderstand one thing on the step by step directions You might Die.
If you fill it up with water and use that trick, but you dont cut right away and the fumes come out of the pores over a days time you could still have an explosion.
When you fill it up with water could there be a hidden baffle that does'nt fully let it fill with water.
If you run a purge of a inert gas how do you know that you purged it enouph.
I weld on tanks all the time and for me its not risky because because I've got 29 years of experience and the know how.
So I'm hesitant to give you advise on this matter because I've had to many guys misunderstand what I told them.
I'd really recommend taking it to a shop thats done this type of stuff before.
BBQ's are cheap compared to what your life is worth.
I deleted my earlier post. The others are correct. This is just too dangerous. I work with people that inert pressure vessels. They did calculations for me on how to purge. So I did that about 10 times over, just to be sure. Then tested what was in the tank.Tim
Many cordless tools...........
2 cordless hammers
2 cordless punches
1 cordless chisel
2 cordless screwdrivers, 1 + and 1 -
and a cordless adjustable wrench that also doubles as a hammer.....
stick a fuse in it and light and run. If it doesn't blow, you should be good to go.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
