Welding table thickness
    There's nothing worse than a table that's too light and spongey and has stuff boucing all over the place when you try to bang on it. My table has a 3" tubing frame with a 4' X 5' X 1" thick top, all sitting on 6" locking casters. It's heavy but moves easily on the shop floor. After using this I'm spoiled and would hate to work on anything lighter!
    You can drill and tap clamping holes, tac weld, and fabricate jigs to a steel top also. Aluminum, in my opinion has way too many downsides.
      I think people are losing the fact that he wants an easy to move lightweight table. My welding table has a 42" x 96" x 5/8 top with 6 4x4" x 3'8 wall legs and a lower shelf with bracing and the whole nine yards. Took a forklift to put it into place. I love it but I would not recommend this to the OP because it doesn't fit his needs.. Maybe if we stay on track more and not recommend tables that do not apply to his needs ...we can offer better suggestions. just my thoughts
      Nick
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      Miller Syncrowave 200 Tig
      2-O/A outfits
      Jet Lathe and Mill
      Jet 7x12 horz/vert band saw
      DeWalt Multi Cutter metal saw
      Century 50 Amp Plasma Cutter
      Propane Forge
      60" X 60" router/plasma table
        ........is this closer to what were suposed to be talking about?.......
        http://www.walmart.com/ip/Cosco-Juve...-Blue/12168125
        I'd probably beef up the top with some 24 guage steel sheet if it was mine
          O.K. seriously.....
          Have you considered getting some 1/4" plate, weld some pipe couplers to the bottom to screw pipe legs into and weld a couple brackets on one side to hold two wheels. You would have a fairly stout table that the legs could be unscrewed and the top could be rolled around like a two wheeled cart and stood up against a wall to get it out of the way.
          When space and budgets are tight you gotta use a little imagination.
            Thanks Nick, This is about my speed. Hobbiest projects, gas grills, hinged boxes for boats, boat repairs and the small stuff. Like I said under 100 lbs. Weight is the issue. I have a step up into the shop, so I'll have to be able to pull and lift in. Dont need a massive heavy table, already have one against the wall with railroad ties as legs and 3/4 inch top, plenty stout for banging on a project. Just want something nice and light enough to move into the center of my shop and sit next to in a chair to do my projects. Thanks again guys for the replys, all good ideas.
            Millermatic 350P
            30A Spoolgun
            Lincoln Pro Mig 140
            Hypertherm Powermax 30
            14" Rage Evolution dry saw
            40 ton press brake
            Evenheat Heat treat oven
            1x42 / 4x48 belt grinder
            • #21
              You could always get 1/8'' steel plate to lay on top of the aluminum and keep it inside.
              • #22
                Ja, I've been there & done that... I know exactly where you're coming from. Making a 1940's tight-squeeze single car garage your "shop" is no easy task! If I were you, I believe I'd find a way to just put a thick aluminum plate on top of your railroad-tie table, maybe a few pieces of 3-4" c-channel under it to insulate it from the wood top... You could make some pockets to store the c-channel under the table like ramp holders on a trailer. Then you could maybe clamp the whole assembly to the table, or have some bolts you drop through to hold everything in place if it wasn't stable enough already.
                Point is, it doesn't sound like you're gonna be doing a whole lot of heavy-duty fit-ups with enormous heat, and since aluminum dissipates heat so well, I think a setup like that would suit you fine. When it comes down to it, pretty much any conductive metal can be used as a welding surface, so do what fits your budget, back muscles, and space.
                Oh, and as far as the child's safety table is concerned, I've used one of those to weld on before; it served me very well for small hobbies.
                • #23
                  Similar to the marketing triangle of "good fast cheap, pick two" I like to refer to a fabrication triangle "light, sturdy, cheap; pick two" Meaning if it is to be light and sturdy it ain't necessarily going to be cheap. If it is to be sturdy and cheap it is most probably not going to be light.
                  Without seeing your shop setup, mostly doors. The reality of transporting a 4'x4' table of any material is going to be a pain in the but unless it is from a concrete drive way to a concrete garage and the table is on wheels. From your posts it sounds you will be transporting this to a non concrete area outside that is not on the same level. Door opening width?
                  If you don't want rust on your table legs, there is this product called....PAINT. Although it does add color to an item its primary purpose it to prevent corrosion (rust). I would highly recommend it, it seems to be catching on these days.
                  Filling the legs with sand is going to do NOTHING to increase their column strength. Only their weight. But then again you want to be able to move this easily? Additionally the sand will hold moisture and cause the legs to corrode from the inside
                  I think your best bet would be to make a top section that consists of a properly braced thin steel plate and 5 (one on each corner and one in the middle) 4"x4" posts that fit into square slots. This way you could store it up against the wall and when needed insert the 4x4's and set it up.
                  I agree with Fusion King, your tools list is extremely......impressive?
                  My favorite welding table is an old cast iron table saw. It is extremely sturdy, very flat and spatter does not stick to it. With its cabinet design the top overhangs in every direction which makes it great for clamping. Unfortunately you can't do much hammering on it, but there is always the steel table for that. Additionally I got the entire thing for $20. Can't even buy the steel top for a standard welding table for that.
                  Best of luck with your ultimate table.
                  • #24
                    Well, first off I'd like to thank everyone for their advice. I spent much time thinking about what everyone had to say and I did many searches on the subject. I decided that an all steel table would be the best long term solution for my application. Might as well do it right the first time. Frame is 3x3x1/8th, top is 3/8th's. Got over the problem of moving it in and out the building by putting 9" casters on the bottom. It roles in and out easy regardless of the weight (doesn't even look funny). Plate top was cupped when I purchased it, so I placed it cup up. Once I bolted the plate down to the frame, Flat as glass..Hope yall enjoy the pics, I'm posting this before I painted it.
                    Ja
                    Millermatic 350P
                    30A Spoolgun
                    Lincoln Pro Mig 140
                    40 ton press brake
                    • #25
                      Nice table you could park a tank on it....
                      • #26
                        Your table looks good. nice job. A couple of suggestions. On my table I cut 4" long tubes out of about 1.5" tubing and welded them under the table at an angle for a place to hold my mig gun. I have 6 locations on my table. Also at each end I have a rail in a wide u |_______| welded under the top to hold clamps etc. 3/8 round would be fine. Everything within reach. With the steel table now you can use the magnetic squares, holders, and torpedo magnetic levels will always be near.
                        Nick
                        Miller 252 Mig
                        Miller Cricket XL
                        Millermatic 150 Mig
                        2-O/A outfits
                        Jet Lathe and Mill
                        Propane Forge
                        • #27
                          Originally posted by ja baudin View Post
                          Well, first off I'd like to thank everyone for their advise. I spent much time thinking about what everyone had to say and I did many searches on the subject. I decided that an all steel table would be the best long term solution for my application. Might as well do it right the first time. Frame is 3x3x1/8th, top is 3/8th's. Got over the problem of moving it in and out the building by putting 9" casters on the bottom. It roles in and out easy regardless or the weight (doesn't even look funny). Plate top was cupped when I purchased it, so I placed it cup up. Once I bolted the plate down to the frame, Flat as glass..Hope yall enjoy the pics, I'm posting this before I painted it.
                          Ja
                          Very neat table design. Can show how the bolts are secured to the table top? Did you drill a recessed hole for the head and then drill a smaller diameter hole all the way through for the bolt threads? Just wondering how you have the bolts below the table top surface.
                          Thanks!
                          • #28
                            First I drilled the holes through the mounts and then through the top. Used a countersink bit on the table top followed by using a flat head (countersink) bolt.
                            Thanks for the comments, thanks for the advice too Monte.
                            Millermatic 350P
                            30A Spoolgun
                            Lincoln Pro Mig 140
                            40 ton press brake
                            • #29
                              ...it's going to sit outside, I don't have a concrete slab outside the shop to keep it on...
                              Pavers are cheap, portable, and will keep the wheels (or steel foot pads) from sinking into the mud & rusting. I keep an engine hoist with cast iron wheels outdoors on them, and after 1.5 years, the wheels look cleaner than than when I moved it out there.
                              Walk softly & carry a BIG SIX ! ! !
                              MM211 + SM100
                              • #30
                                Well I decided to clean out my shop and make some room so that I wouldn't have to worry about keeping it out in the weather.
                                Millermatic 350P
                                30A Spoolgun
                                Lincoln Pro Mig 140
                                40 ton press brake
