Pocket size layout guide for holes.
  • Pocket size layout guide for holes.
    I do lots of hole layout at work in steel pipes and i can remember the holes sizes but i can't set my dividers from memory. So i like everyone else hold my dividers up to a tape measure or use a rule to set them. Then i made this aluminum plate with a center and the rest of the hole sizes layed out in a semi circle. So now i just stick one leg of the dividers in the center punch mark and the other leg in the size i want. Simple enough. Sure knocked off a bunch of time when you have to layout 25 holes all different sizes. I even have room for sizes i might run across sometime Standard size fittings on the right and 3000# fittings on the left...Bob
    excellent idea!
    Professional firefighter (retired). Amateur everything else I try to do...
    Oh yeah: GO BIG RED!
      Nice.... Except for the decimals
        Nice, but a few questions.
        1) why not just use a strait line for each length?
        2) seems to be a large jump in space from the 1" to 1.5" verses the 1.5" to 2"
        3) no 3" ?
        2- XMT's 350 cc/cv
        1- Blue star 185
        1- BOBCAT 250
        1- TRAILBLAZER 302
        1- MILLER DVI
        2- PASSPORT PLUS
        1- DYNASTY 200 DX
        1- DYNASTY 280 DX
        1- MAXSTAR 150 STL
        1- HF-251 BOX
        1- S-74D
        1- S-75DXA
        2- 12-RC SUITCASES
        1- 8-VS SUITCASE
        2- 30 A SPOOLGUNS
          3) no 3" ?
          Straight would work.
          Don't know about the jump as those are the OD's of the couplings i use.
          I don't use a 3" coupling and the size could be added but our shop didn't have one laying around to measure...Bob
            Excellent idea Bob. Thanks for sharing. Will be making one for our shop
            252 Miller Mig
            180 Synchrowave
            R - 45 Milling Machine
            Kingston 1100 Lathe
            Miller 2050 Plasma Cutter
              good idea, now I know what I'll build next time I'm waiting on parts
                3) no 3" ?
                I think the #s on the right are correct but the #s on the left seem to be messed up...FWICT
                MillerMatic 211 Auto-set w/MVP
                Just For Home Projects.
                  The left side is for 3,000# couplings are both sides are correct to the fittings. There is a line for 2" pipe on the right side as its the only size of pipe i use so i put it there. I make special tanks and pressure vessels and these are the sizes i use. More can be added at any time...Bob
                    I get it now...thanks.
                    It would have helped to read the post not just look at the pictures...
