Few pics of railing just did.
recent job
Um...NO
Originally posted by drpipe View PostHmm is that just 1 1/2? Pipes cut at random lengths and shoved into wooden posts then painted with a rattle can?MillerMatic 211 Auto-set w/MVP
Just For Home Projects.
The brackets are anchored with lag screws into the post.Attached FilesBB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
Originally posted by walker View PostOh, you used lags. Next time try a birch dowel at about 75 amps, to stick weld them on. If you get the foil covered dowels from the craft store you can do aluminum to wood as well
Looks good.BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
Originally posted by walker View PostYou just keep the amps low, and like some guys do with 6010, you can dunk 'em in water, as they need a little moisture to lay a good bead.
edit: sorry for hyjacking the subject, the work done is a good job and i'm sure the customer is happy about it.
note: english not being my first language people here made me work harder to keep up with the birch dowell thing...lmao too ;o)Last edited by snowbird; 07-11-2012, 03:15 PM.
Originally posted by drpipe View PostLmfao ........ Did ya stove pipe it
screws to the post. Pipe railing is welded to the bracket. Hard to see to a untrained eye. Pipe and brackets are black and post are white.
recent job
Bd1 I use my iPhone to play on the net at work when I'm not making flawless welds I come here or surf **** sites ....... Pardon me to the welder I was looking at very small pics ...... Bitty1 your not going to get me going cause your not worthy to carry my rod bucket
Originally posted by drpipe View PostBd1 I use my iPhone to play on the net at work when I'm not making flawless welds I come here or surf **** sites ....... Pardon me to the welder I was looking at very small pics ...... Bitty1 your not going to get me going cause your not worthy to carry my rod bucket
Originally posted by corbyndad View Postdrpipe should be bought for what he is worth and sold for what he thinks he worth. I always say show your worth with your work not your mouth. flawless welds blah blah blah don't hurt your shoulder pattin yourself on the back. What a Richard!
