Originally posted by sjmiller
Learning to TIG in Chicago ??
The Challenge
Every since I took up welding as a hobby, I notice the weld bead on everything around me, from stairs to motor cycles to ....
I had to drop off a package at FedEx the other day, they have Alum. hand trucks that had butt ugly welds. The bead starts out about 1/4" and is almost 1/2" after 16 inches - no heat control - burn baby burn.
Now look at an expensive bicycle - the text book ripple every 1/32" - something to strive for.
Steve
Thanks hilruner. good advice. Aluminum gets shinny lookin and then its gone<smile>. I've made a few nice holes in aluminum with a torch, aint at all like steel. I haven't yet even tried to mig aluminum, shoot, just recently learned how to make a half way decent looking bead with good penetration with a mig< lincoln 175plus> on steel. Took me awhile to get the hang of migs automatic feeding of the filler material. I think tig will be easier for me because its more like gas welding even though the experts say its harder to learn.
Learning to Tig
To answer bfloyd4445's question. Start with steel. If you want to try aluminum you might want to step up to 1/4" plate and remember; as heat builds in the piece your travel speed will have to increase, unless you've got a foot pedal and can reduce amperage.
HTP over in Arlington Heights holds a "beginner TIG" class every month or so; give Jeff Noland a call over there, he can give you the details. It was a good newbie introduction to basic TIG welding with an inverter rig for my wife and I. I don't remember specifically, but I think the class was either $75 or $100.
Guest repliedToo early...
I like that idea. Do I set up the A using aluminum or mild steel? Thanks for the tip HILRUNR. I too am about to dive into tig, I do weld at work when the need arises, or should I say, I splatter at work when the need arises, and your idea sounds like a good way to practice.
Learning to Tig
I don't know if they have them in the Chicago area, but our high schools in Tennessee have continuing education courses at night for around $75. The local community college also allows you to audit classes for less than full price. There's no way to give enough tips in this forum but here's one - stand two pieces of light gauge metal to form an "A" then tack each end. Practice welding the ridge without filler metal till you get a smooth bead with about 1/32" penetration.
Good Luck!
bead quality
This thread is just what I was looking for. I have a sync 250. I've studied the calculators for tungsten size, filler size, amps, etc. I've studied the educational page on Miller's site. I weld as a hobby, but also can't really seem to get it. I would say my biggest problem is the filler metal. I cannot get it to melt nicely in the puddle - it tends to "stick" to the puddle. Other times it goes right through the puddle, BUT I don't have a hole in the finished workpiece like "burn through".
Any help?
Everyone laugh now - before you read further...
I had a project design finished, but my metal suppy isn't open on the weekend so I found some aluminum at OSH. I founfd out the hard way that you can't weld anodized aluminium....
It kind of bursts - when the heat level gets to high.
Steve
slow tig
I taught myself to tig Im by no means an expert. I purchased a book & a miller 180 recomended by the experts at my local welding supply. you have to go slow I wanted a mig however I was told for the alluminum I weld the tig was the way to go. make sure your weld joint is clean ( very clean) and weld slowly one spot at a time. make sure you are sitting in a comforatable position the dynasty is supose to be eaiser to use than the 180 I purchased. If your metal is not clean it will splater If that happens stop & clean the area. sand wipe with asatone.
There is one thing for sure - keep the TIG electrode out of the weld puddleThis is a hobby for me and so far removed from what I do - I get a "you're kidding" from peers when they ask what I like to do for fun.
Let me know what you think about the book when you get it.
Steve
Hey Steve...looks like the reviewers on amazon agree with you! I ordered it (from buy.com, 10% cheaper than amazon). Thanks for the tip. I'm getting a bit better on the steel, still a little confused on exactly what to do with the torch after the puddle starts. Do you move the puddle in a straight line? Pull back as you add the filler, pause it, move it in circles, or just keep it moving at a steady rate? It seems like all those get the job done, but whats the right way to do it?
thx
Rob
I would also recommend the book "Welding Principles and Applications" fifth edition by Larry Jeffus - it's not cheap - worth every cent.
Steve
Thanks for the advice, guys. I ordered the Miller Student package, that does seem like a lot of stuff for $25...I tried some more welds today, and made a few good ones. I think I'm gonna follow WB5JHY's advice and see if I can find someone skilled at TIG to work with me for a couple hours, to make sure I have my hand movements down, and so I know how to read the puddle better...
Rob
