I've been noticing that when my mig gun line has a loop or coiled in it the wire feed is not constant and smooth. The gun is older and has seen lots of use. Does the group think the liner needs to be replaced or could it be something else involving the wire feed. When I say it has a coil in it, I mean the line will sometimes coil around and lay on itself when I'm welding. I don't always have the Mig gun line completely pulled straight before welding.
Mig gun liner
One of the biggest problems with wire feed binding is dirt in the liner.
Before you go out and buy a new liner, take your current liner out and soak it in some acetone for a day then blow the liner out with compressed air. Sometimes you may have to do this a few times to get all the crud out of it.
I dont recommend this for a teflon liner as I would think the acetone might melt the teflon but for a normal coiled steel liner this works very well.
Always make sure to put the felt wiper back on the wire when changing an empty roll out.
Hope this helps you out
Tek
Millermatic 350P
Dynasty 200Dx
Hypertherm Powermax 1000
Victor Journeyman O/A
Offshore Mill and Lathe
Tunes to weld with by Peavey
mig liner
I think I've heard the current can swell the wire making it "sticky" in the liner. This could be bullcrap.
My own feeling is that coils, or bends make smooth feeding difficult. Have you ever tried pulling electrical wire through conduit? The radius diameter AND number of bends makes it much more difficult.
i agree
Originally posted by drewwormI think I've heard the current can swell the wire making it "sticky" in the liner. This could be bullcrap.
FarrisLast edited by fyoung; 07-31-2006, 06:03 PM.Gone But Never Forgotten!
I just had similar problems w/ my 350P. But it also would sputter alot at starts and during the weld. I was told to pull the liner and look for kinks. If no kinks in liner then while you have it out use your luber cleaner and pour it in one end and miraculously junk came out. Also check your rollers for wear. If they are worn out and you keep tightening pressure on them your not doing anything.
Good Luck, JWOOD
