I was vertical mig welding yesterday on a trailer in my shop wearing a t-shirt, short leather gloves, and a pair of Miller Welding Sleeves - (INDURA® Cotton & Pigskin Leather), and a ball of molten slag landed on the cuff area that appears to be polyester. The result was a painful arm trashing and yelling. As you can see in the photos, the blob danced around a minute inside the cuff before I could remove it. I know I should have used longer welding gloves, but it was hot at the time. I wish they could have made the welding sleeves all leather with elastic in the end. I must re-evaluate my use of these sleeves...
Miller welding sleeves
Yup i get them everyday too and they have burned thru everything i wear or always find a small hole. Wait until you get one down your boot or dancing around in your ear and you can't do anything for either except wait it out. I caught a large piece of gas flux core slag on my lip yesterday and it still hurts today. Just part of welding...BobBob Wright
The short leather gloves is the problem, not the sleeves. With long gloves they will overlap the sleeves and protect you from this. The source of the sparks is usually above your elbow level and your arms are bent slightly upward while doing the welding. If the gloves overlap the welding sleeves the sparks will just roll off like water running off shingles on a roof. I work with long gloves and welding sleeves quite often and the only time that I have managed to burn my wrists is when reaching downward and welding. For this position I have learned to pull the sleeves
over the gloves.
Charley______________________________
Miller MM252
Miller Bobcat 225NT
Miller DialArc HF & DIY Cooler
2 Miller Digital Elite and 3 Fixed Shade Helmets
2 O/A torch sets
DeWalt 18 volt 1/2" Driver/Drill
DeWalt 18 volt 6 1/2" Metal Saw
DeWalt Porta Band & SWAG Offroad V3 Table
Milwaukee 8" Dry Cut Saw
Milwaukee 14" Dry Cut Chop Saw / Delta Stand
Milwaukee 9" Grinder
2 Milwaukee 4 1/2" Grinders
Milwaukee Hole Hawg 1/2" Drill
Wallace 5 Ton Gantry
Too many hand tools
Welcome to welding!!! Those are minor burns compared to some that I've gotten. Welding in tight spots you're going to get them all the time. I've had blobs burn through the tongue on my boot and put 3rd degree burns on the top of my foot. It's all part of the job my friend.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
i got an orange jacket thats really thick cotton. when i stick weld i just use drivers gloves. when i weld decking down i only use one glove. the galvanized sometimes explodes and gets down the glove is reason i only wear one. plus my stinger gets pretty warm. i run 302tb wide open welding decking. running 232 wire ill use regular welding gloves. it gets WARM
hmm
Originally posted by aametalmaster View PostYup i get them everyday too and they have burned thru everything i wear or always find a small hole. Wait until you get one down your boot or dancing around in your ear and you can't do anything for either except wait it out. I caught a large piece of gas flux core slag on my lip yesterday and it still hurts today. Just part of welding...Bob
i have this heart shaped burn on my right wrist the size the size of a golf ball, lying flat on my back stuck under my jeep welding 7018 over head, had the flu, tried to keep busy, then coughed, funny thing, on valentines day, 3rd degree burn, it made me think of what burn victoms go through, take it in stride
I use long cuffed gloves, long sleaves (welding jacket when stick welding). If your burning yourself like that, your not wearing the proper safety equipment for welding.Lincoln Idealarc 250
Miller Bobcat 250
Thermal Arc Hefty 2 feeder
Thermal Dynamics Cutmaster 52
Torchmate CNC table
