Framing saw to cut through metal???
    Originally posted by beamwalker View Post
    makita. We have 2 of them evolutions we tore to pieces very shortly
    Which type of blades do you use on the MAKITA?
      We haven't cut any stainless yet, mostly mild steel. I did cut some aluminum for a couple of small projects and didn't experience any problems. A light spray of PAM cooking spray on the blades when cutting the aluminum helps keep the blade clean. After normal preparation the aluminum pieces TIG welded fine. Saw blades remain quite clean when compared to grinding disks. With grinding disks you get metal chips embedded into the disk, and they can easily get transferred and mixed into the surface of other metals. This doesn't happen with saw blades, drill bits, milling cutters, or lathe tooling.
      If you don't guide these metal cutting saws and you try to free-hand cuts as you would a sheet of plywood you will tear up a metal cutting saw blade in a very short time. These blades will last for hundreds of cuts if you don't bind the blade in the cut or stop in the middle of the cut and then try to resume. The metal will work harden and dull the blade when you try to resume the cut. It only takes one bind or hardened metal spot to ruin a blade. Avoid cutting rebar or hardened metal with these saws. Use abrasive blades for this type of work.
      Charley
      ______________________________
      Miller MM252
      Miller Bobcat 225NT
      Miller DialArc HF & DIY Cooler
      2 Miller Digital Elite and 3 Fixed Shade Helmets
      2 O/A torch sets
      DeWalt 18 volt 1/2" Driver/Drill
      DeWalt 18 volt 6 1/2" Metal Saw
      DeWalt Porta Band & SWAG Offroad V3 Table
      Milwaukee 8" Dry Cut Saw
      Milwaukee 14" Dry Cut Chop Saw / Delta Stand
      Milwaukee 9" Grinder
      2 Milwaukee 4 1/2" Grinders
      Milwaukee Hole Hawg 1/2" Drill
      Wallace 5 Ton Gantry
      Too many hand tools
        Don't buy the Evolution saw. I bought one early this year for a job and have used it quite a bit. It rattles itself apart, pars are continually falling off of it, and the the cheesy plastic miter gauge/lock thing slips. The blade height adjuster also slips about every other cut. I have no tried other brands, so can't reccomend another one though.
          Save your money.
          Buy a small plasma torch put a drag shield on it then use a straight edge.
          Save more money,
          Buy the circle cutting attachment for the round holes.
          Once you go plasma you don't look back!
          Steve
          Bobcat 250EFI
          Millermatic 350P
          Hypertherm 1250
          A Bunch of tools
          And a forklift to move the heavy stuff with..
          Torchmate 2x2 CNC Plasma
          It's Miller Time - Get Back To Work!
