Framing saw to cut through metal???
  • Framing saw to cut through metal???
    I'm thinking to get me a framing saw to cut some steel, I read that the framing saws with a Diablo steel blade are good. Up to which thickness I can use this method?
    Homedepot's Ridgid 6 1/2" VS Harbor Freight 7 1/4" Chicago Electric?
    Thanks
    Wood cutting saws are really too fast for cutting metal. It will work, but the blade suffers with shorter life and doesn't cut as well at that speed. You should purchase a metal cutting saw. They have a lower blade speed and do the job well.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF & DIY Cooler
    2 Miller Digital Elite and 3 Fixed Shade Helmets
    2 O/A torch sets
    DeWalt 18 volt 1/2" Driver/Drill
    DeWalt 18 volt 6 1/2" Metal Saw
    DeWalt Porta Band & SWAG Offroad V3 Table
    Milwaukee 8" Dry Cut Saw
    Milwaukee 14" Dry Cut Chop Saw / Delta Stand
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Milwaukee Hole Hawg 1/2" Drill
    Wallace 5 Ton Gantry
    Too many hand tools
      hmm
      don't know about those two but a skill mag77 with a carbide tipped blade will cut right through 1/2inch ply and a steel sawhorse like butter don't ask how i know
        This one is very nice
          I found an old SKIL SAW, will get a nice blade and try
            What gauge or thickness are you cutting ? I bought the HF STEEL cutting circular saw and it is good. I don't need the big buck real saws so the HF it was. I got it for around 60.00 with coupon and it paid for its self already. I was going to buy the Milwaukee but it would have been almost 200.00 more. I used it for cutting 12 and 18 gauge plus 1/4" plate. I cannot complain. If you need it every day then go for a real steel cutting saw. good luck
              hmm
              not sure bout the power of that saw i was talking about one of these skill mag77 worm drive http://www.google.com/url?sa=t&rct=j...E_3MUoxcmV4C5w
                Mostly 1/8", but want to do some skid plates for my Jeep and those will be 3/16" maybe 1/4" no bigger than that.
                  Steel cutting saw
                  I have the saw listed below, I cut 1/2" mild steel with it a lot. It will cut bigger but I haven't done it yet. The key is lock a straight edge on the edge for a guide so it doesn't bind. Blades are 85 buck or so and use the manfact recommended. It has saved me lots of time!!
                  Milwaukee 6370-21 13 Amp 8-Inch Metal Cutting Circular Saw.
                    1/8" and up is too thick for a wood circular saw. That being said, I have cut THOUSANDS of feet of 26ga steel sheeting with my makita 7 1/4 circular saw. If you can find them, the Tenryu metal cutting blades are much better and last longer than the steel demon. For wood though, every one of my saws has a red diablo blade on it.
                    For 1/8" up to 1 1/2" bar grating I use my Champion metal cutting saw. http://www.championcuttingtool.com/pdf/rs725.pdf
                    my only complaint is that is uses a blade with a weirdo 20mm arbor hole.
                    Bobcat 225NT
                    Cutmaster 52
                    Lincoln Weld-Pak 100 buzz box
                    Caterpillar TH63
                    '07 Kawasaki ZZR600
                      double post.
                      Bobcat 225NT
                      Cutmaster 52
                      Caterpillar TH63
                      '07 Kawasaki ZZR600
                        makita. We have 2 of them evolutions we tore to pieces very shortly
                          Everyone has there own opinion of course . I work in a fab shop we have several of the metal cutting saws. Skill mags and another brand. They are ok if you take the time to clamp down a straight edge ...... Make sure you clean out the shavings trap after each use . Now I think using a skill saw with a metal blade works about the same . They both pretty much suck and are so loud . I use a track torch or my trusty burn bar and use a torch for half inch and up and a plazz cutter for 1/16 up to half . I cut some two inch plate last week with a track torch and number three tip. Then I finished making the final cuts by hand with a torch with number two tip and my helper holding a rose bud ahead of my cuts...... It looked great .
                            Charley
                            Do you have to change the blades of saws if you go from mild steel to stainless or aluminum so that the saw blade doesn't cause it to rust? I know you have to change grinding pads if you're going from mild steel to stainless or aluminum.
                              **** no
