hi, could never decide on how I wanted to store the 3/4" pony pipe clamps. Used a recycled piece of 4" pipe with flange, weld plate to inside flange bottom, Dropped 3/4" threaded rod into flange holes and weld, cut 1/4"x2" flat stock 3/4" wide and welded to 1" pipe coupling and then weld to 4" pipe. With inside plate on bottom I store my bar clamps inside the 4" pipe.I should have done this years ago. Takes up very little space and you can spot the length of each clamp.
Pony pipe clamp storage
Thanks. I got quite a few scraps of 4'' with flanges. I made up a spool piece about 36'' face to face on flanges. Then had a 20'' square piece of plate that I
welded some 5/8'' studs to so they match the flange bolt pattern on center. Now I have a roll about flange to flange table top. Just remove when storing.
