Hello,
I just purchased a TIG machine. I've welded with stick and oxy-acetylene in the past, but my only exposure to TIG has been watching American Chopper
I HAVE read the owners manual, my questions weren't answered within. And I'm looking into a night course for experience, but the next one is several months away. So, while I hate being the new guy begging for help, well, that's what I'm doing....
OK, so I have a Maxstar 150 STH. I'm welding steel, and I'm using pure Argon. I'm using thoriated tungsten rods and I've got three sizes, .040, 1/16, and 3/32. So far, I've been using the smaller two. I'm using the machine in lift-start mode, and I'm able to start the arc relatively easily, and can put down a decent bead.
The machine came with a remote control (finger operated), and the owners manual refers to it as 'optional'. That says, to me anyway, that I don't NEED to have it connected, so I've not connected it yet. But after an hour or so of experimenting with various speeds, currents, and electrodes, I'm wondering a couple things.
First, how do I stop the arc when I reach the point at which I want to end my bead? Obviously, I know that it will stop if I lift the torch far enough, but if I do that, I'll no longer be protecting the weld pool and the filler rod end with the shielding gas! So, there must be a way to stop that arc without lifting the torch. Is that what the remote is for? If there is no other way to stop the arc, then how can the remote be 'optional'?
Second, if I attach the fingertip control, how do I utilize it? Do I start with it wide open and adjust the current once I've established the arc? Or do I set it like I do the front panel control, and just adjust as necessary? Does it vary the current from 0 up to what I've got the front panel dial control at, or does it override the dial altogether?
Third, does the remote control have any direct effect on the gas flow? As I understand it, the gas flow starts when the arc is established, and it runs for some time after the arc is stopped. Does the remote control change this? If so, how?
Fourth, does a foot pedal do the same thing as the fingertip remote? The fingertip remote seems to me that it would be awkward to manipulate while simultaneously holding the torch and filler rods at the proper location. Should I just lose the fingertip remote and get the foot pedal?
I apologize for asking what are probably dumb questions. I could probably answer them myself through trial and error, but I cannot get out to the garage to practice anymore until later this week, and in the meantime, I'm dying to know the answers to these questions....
Thanks in advance
Art
Thanks in advance
Art
