I'm going to build a new gas tank for my boat. I not really sure what thickness of aluminum to use. The gas tank will hold 12 gallons of fuel. Any Suggestions?
Aluminum Boat Gas Tank?
YUP
use 5052 at least .100 thick and weld it with 5356.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Originally posted by bostoncanadawelder View PostI would use .125 with the gas tank and also TIG and mig weld it with and bondo the edges. You need to test it for leaks before hand.
Fusionking is correct, but you can use .125" also if it is easier to get.Last edited by MMW; 01-16-2012, 05:31 AM.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Is this going to be a portable tank or a permanent install? If a permanent install, I would go as large as practical, as boats tend to burn fuel at a pretty good rate, and the more fuel you have the longer you can stay out on the water. But a portable tank starts to get pretty heavy after 12 gallons. Gasoline weighs about 6Lbs. per gallon, so your looking at 72 Lbs, plus the weight of the completed tank. Go over all your welds very thoroughly before adding fuel. Even if you test for leaks with water first, be aware that gasoline molecules are smaller than water molecules. Meaning if, even though it doesn't leak with water in it, don't mean gas won't find a small pinhole if there is one. Double or triple check it for leaks after it's filled with gas. After filling with gas it will be too late to go back and do anymore welding W/O serious purging effort and major cleaning, which might not get out ALL fumes. BOOM BIG TIME.
Even BONDO may not hold up as a permanent fix when exposed to gasoline for extended periods, check it often in the BONDO area if you end up using it. Does anyone on here KNOW(not just THINK it does) if BONDO will hold up to exposure to Gas?Last edited by Bistineau; 01-16-2012, 07:13 AM.
Typical thread.
OP asks a question and gets an answer from a "pro" who knows what he's talking about and gives the correct, detailed explanation.
Then the "peanut gallery" chimes in with a bunch of mumbo jumbo BS (mig, tig, bondo----yeah, right) and a bunch of other irrevelant crap.
Just confirms the old statement:
If you can't dazzle them with brillance, you can baffle them with bullsh1t.Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
R
The way I would do it is, 1/2" 5052 using 4043 filler applied with a caulking gun. Make sure you duct tape the inside seams first. Before pressurizing to 125psi smear a good amount of jb weld to the outside corners. Fill with gas and pressurize. That's how I would do it. However I don't own a boat or welder.
Originally posted by lamename View PostThe way I would do it is, 1/2" 5052 using 4043 filler applied with a caulking gun. Make sure you duct tape the inside seams first. Before pressurizing to 125psi smear a good amount of jb weld to the outside corners. Fill with gas and pressurize. That's how I would do it. However I don't own a boat or welder.
Funny... but not that funny...
we probably have enough clueless neophytes in the audience...... so a few might miss the joke and take that for gospel......then pester you into the hereafter with truly lame questions......
Originally posted by wrench3047 View PostJB Weld, is spray or short arc?
'77 Miller Bluestar 2E on current service truck
'99 Miller Bobcat 225NT for New Service Truck
'85 Millermatic 200 in Shop
'72 Marquete 295 AC cracker box in Shop
'07 Hypertherm Powermax 1000 G3 Plasma Cutter in Shop
Miller Elite and Digital Elite Hoods
Help the guy!
I did mine this way 5052, corner welded with 5356 AL. Dynasty 200 dx set at 150 amps, 70 bal and 125 freq. ,with a on off button on the water cooled torch. Tacked and started at 1 end to the other, paused for cooling.
Then presure tested thru the fittings at 4 lbs PSI, soaped tested and found 2 pin holes. Ran over them and all is fine. Not sure if this guy is BS or just needs HELP???
