Couple of pics of a mini excavator dozer edge i did last week for a customer.The edge is 5/8"thk x6"wide 60"long.Mig welded it with .035 70s6 .Preheated a little to slow the cooling.
Cat 303C Dozer Edge
No the thick edge down on this.If i was welding it into a bobcat bucket the the thin edge would be forward.This is weldable bucket lip i use for doing this.Last edited by admweld; 01-09-2012, 09:37 AM.BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
The beveled part is about 1-1/4" so when it wears,which would be quick with the thin part you are now into the the thicker section anyhow.The blade is 3-1/2"below the push board.Do it anyway you like, this is how i,ve done them for 10+ yrs have not had a complaint about it yet.BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
blunt end
One nice thing with the blade like that, back dragging would be very nice. Never seen a blade like that on the mini's, most seem to round out on the bottom and is left that way. One thing I am wondering, how big of a gap is that between the end of the blade that you installed, and the edge of the mini's blade?
blade
Originally posted by admweld View PostThis will round over more with wear.The old edge is cut off before installing this one if thats what you are refering too.
Originally posted by admcnich View PostVery cool, I was refering to the side, I think it was pic #2. It seemed that the edge was a little shorter then the blade on the mini.BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
