New project pics
  • New project pics
    I finally broke down and bought a bender. 100% of the materials for the stand were scrap I had picked up.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    verry cool.
    cant wait to see what ya make with the bender.
    thanks for the help
      What stops it from spinning on the floor? I have a bender I made (in the project gallery) mounted to a 4x4 ft table with 3/8 steel top, 4 3"sq legs x 3/8" wall, with a shelf 10" off floor same size as table, a 6" vise mounted, a 30"' shear/brake/roll plus other heavy stuff and until I bolted it to the floor it would move on heavy bends. This table must weigh at least 400 lbs without the tools on it.
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      Miller Syncrowave 200 Tig
      2-O/A outfits
      Jet Lathe and Mill
      Jet 7x12 horz/vert band saw
      DeWalt Multi Cutter metal saw
      Century 50 Amp Plasma Cutter
      Propane Forge
      60" X 60" router/plasma table
        looks cool.
        i was wondering the same thing about it moving
        Read or submit reviews of Lincoln, Hobart and Miller Welders atThe Welder Shop.
          hole augers
          Im buiding a picket fence ,need to auger out 35 holes 2ft.deep X 4" dia..Rental is ok,,,but I rather have my own,,any suggestions on a good 2 person auger to buy .thanks ............
            Unless you're planning to do larger work also............
            I have a 1 man Earthquake turning a 8" auger. It has a two stroke engine which starts easily, is lightweight, and doesn't cost an arm and a leg. I think Home Depot has them. I like mine. Check them out. They also have larger Earthquake models also.
            Nick
            Miller 252 Mig
            Miller Cricket XL
            Millermatic 150 Mig
            2-O/A outfits
            Jet Lathe and Mill
            Propane Forge
              Looks good. I also was wondering about it moving and also how you got the plate welded solid to the brake drum. We tried doing that at work for a stand we built and finally gave up and bolted it to the drum cause we couldn't get a solid bead on it. Just wonderin if there is some special technique to it. Otherwise, nice bender and stand and be sure to show us what you make with it!
              At Home
              Miller Thunderbolt XL AC/DC
              Performance Tools 6" Bench Grinder
              Craftsman Hand Tools
              Craftsman Cordless Drills
              DeWalt Angle Grinder
              1976 AMC Jeep CJ7
              1980 Ford F150 Custom
              1994 Chevrolet Silverado C1500
              At Work
              Miller Bobcat 250
              2 Miller MM251s
              2 Miller MM252s
              Miller Dialarc 250 AC/DC
              Lincoln Idealarc 250 AC/DC
              Snap-On Flux Core Welding Machine
              Hypertherm Plasma Cutter
              Victor Torches
              2006 Chevrolet Silverado 2500HD 4x4
              Proud American Ham KE5TJA
                moving, et al
                Originally posted by bryce_burden View Post
                ...how you got the plate welded solid to the brake drum.
                I haven't used it yet. However, if I have a problem with it moving, I plan to overbore holes in the floor and cement 1/2" nipples in them. Then weld ears made of angle onto the base and secure the whole shootin' match with cinch pins. Thats what I be thinkin'.
                I will shoot some pics of my beads tomorrow. I welded the plate to the brake drum with my Maxstar 150STL, DCEP, 1/8" 6010 5P+, ~95A.
                HTH
                Triggerman
                CST-250
                  Well how many Tigrs' you got thought i saw two in the back ground, or maybe all those flashes are makeing me see double!!
                  Miller Digital Elite inferno
                  Miller MP-10 passive helmet
                  Hobart Stickmate 250/160 ac/dc
                    me thinks the 2nd one is a spectrun 375 extream maybe....just a guess though.
                    thanks for the help
                      Give that man a cigar!
                      You are correct, James. One is a Maxstar 150STL and the other is a Spec 375-Xtreme.
                      Triggerman
                      CST-250
                        woooo, hoooo, wheres my cookie.
                        nice setup.
                        thanks for the help
                          Not much of a welding project but a project just the same.
                          I was having difficulties getting some of the heavier pieces of scrap metal out of the bin at the scrap yard. The bin was made up from an old tanker trailer cut in half. I struggled for about an hour the last time trying to get a piece out of there that I was interested in that weighed 150 lbs.
                          I had a cheap winch at home that i decided to fasten to my trailer hitch in case I ever needed a little help over at the scrap yard again. I rigged up the power to the trailer plug-in. I then decided latter on to see if i could fasten my contraption to my shop ceiling to use it there when not in use on the pick up. This is what I came up with.
                            That is a winch and not a hoist.....................be careful when it is carrying
                            weight............it was not designed to.
                            Nick
                            Miller 252 Mig
                            Miller Cricket XL
                            Millermatic 150 Mig
                            2-O/A outfits
                            Jet Lathe and Mill
                            Propane Forge
                              You're absolutely right, in no way will I be using this for anything heavy and whatever I will be lifting, I won't be laying under it that's for sure.
                              Thanks for the advice
