I know that using straight co2 through an argon regulator is possible (at low flow rates to prevent freezing), but what about the other way around? Can I use argon through a co2 regulator? The flowmeter will be inaccurate (since argon is less dense than co2) but is this the only issue that I will encounter?
argon thru co2 regulator
Originally posted by mk10 View PostI know that using straight co2 through an argon regulator is possible (at low flow rates to prevent freezing), but what about the other way around? Can I use argon through a co2 regulator? The flowmeter will be inaccurate (since argon is less dense than co2) but is this the only issue that I will encounter?
I have two Smiths flowmeters. One is marked for Argon, Helium, C02 and the other is marked Argon, C02. That means that either of them can use either Argon or C02.
The difference is in the scale markng for each gas and that's only about 1/2" at the top of the tube. My MIG is usd on straight C02 at around 15-20 scfm and has yet to freeze up. At that setting, the scales are almost exactly the same. C02 will, of course, freeze a flowmeter if you use excessive gas flow rates.
There should be no difference in the structure of the flowmeters since both of the gases are inert. I would say that you will be OK.Last edited by Synchroman; 02-15-2008, 04:49 PM.Miller Syncrowave 200
Milermatic 252
Lincoln AC/DC "Tombstone"
The regulator that I have is a Victor HRF2380--the HRF2325 is its argon counterpart. The differences between the two seem to be:
co2
- preset outlet pressure: 80 psig
- flowtube scale: 8-28 scfh
- safety relief valve: 150 psig
Argon
- preset outlet pressure: 25 psig
- flowtube scale: 10-50 scfh
- safety relief valve: 60 psig
Do you think I need to adjust the preset pressure screw to compensate for using lower density argon?Last edited by mk10; 02-15-2008, 06:37 PM.
Originally posted by mk10 View PostThe regulator that I have is a Victor HRF2380--the HRF2325 is its argon counterpart. The differences between the two seem to be:
co2
Argon
You got me. I would simply hook it up and give it a try. The only adjustment on my flowmeters is the scfm flow rate.Miller Syncrowave 200
Milermatic 252
co2
Argon
Do you think I need to adjust the preset pressure screw to compensate for using lower density argon?sigpic
Clint Baxley
Baxley Welding Service
Rembert, SC 29128
