Pass Port Plus
  • Pass Port Plus
    Picked up the Pass Port Plus last week. This week I want to get the spool gun for it. What all do I need to run aluminum on the Pass Port Plus? Spool gun, gas and wire? What type of gas for the aluminum?
    Thanks....
    ProWorkz,
    Congrats on the new machine The Passport is great little unit and really packs alot of punch for it's size. To set your machine up for aluminum you will need these items:
    Spoolmate 100
    1 lb spool(s) of aluminum wire
    A bottle of 100% Argon gas
    Regulator and gas hose for the Argon
    You may want to get some extra contact tips also.
    Kevin
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
      Spool gun
      Kevin thanks for the reply. I picked up the spool gun two weeks ago. I plan on running my first aluminum beeds this week with the spool gun. What is a good flow rate for the Argon? Thanks.....
      Dave
        ProWork,
        Last week I got my 5th PassPort + and they all weld just about the same.
        When you startout with the PassPort + you'll need to start on the low side of the rrecommended settings. The little PassPort + has alot of power and I find the factory settings are kinda high. Also, when you adjust the machine, I have found that the adjustment knobs are VERY sensative. Each little click makes a big difference.
        Good luck,
        Bulldog
        5 Passport Pluses
        2 MM 212's
        MM 210
        MM 251 MIA
        MM 350 P w/Python
        w/ tig runner
        Trailblazer 302
        12RC w/meters
        Spectrum 1000
        Spectrum 2050
        2 Black BWEs
        Joker BWE
        Star & stripe BWE Digital
        2 star & stripe xlix's
        REAL TRUCKS RATTLE
        CUMMINS BABY
          Pro,
          20 to 25 CFH should be all you need.
          Kevin
          Kevin Schuh
          Service Technician
