im working on a hitch mounted smoker to tailgate with. drafted up a design on Inventor today. ill post some pics when i get any.
Lets see your pics of some small projects
This is a stand that I built to make my bead roller mobileAttached Files
Originally posted by alumidrew View PostApparently all my pics. are too big.
bummer
or http://www.irfanview.com/
Good luck
L*S
Cutoff Saw Stand - Evolution 355
Here are some pics of a cutoff saw stand for an Evolution 355. The right hand table wing is held up by a folding support arm and includes a pull-out extension. The unit is mobile to save shop space, pull out handles are used to move it. One foot is adjustable to accommodate irregularities in the shop floor concrete. Attached to the support table wing is a folding ruler that give quick approximate readings for fast cuts. There is a small slide-in chip deflector just to the right of the blade to keep the metal chunks from flying all over. There is a 3/4" plate on the bottom to act as ballast to prevent tipping. I've used this setup for about 2 years, works really great.MTBob
____________________________
MM 251 w/Spool gun
MM 135
Evolution Cut Off saw
Logan Lathe
Clausing Mill
Walker Turner Drill Press
This is a breaching door that I made as well as a battering ram device. The ram in the pic was a prototype and the final version was changed a bit. I made many of these. Dave http://jerseytactical.com/products/P1010822252.JPG http://jerseytactical.com/products/P1010819.JPG http://jerseytactical.com/photo_gallery/P1010127.jpg
Made some aluminum ramps for a local trucker, he wanted me to test them with my welding rigKelly
Trailblazer 301D
2 XMT 304's
Dynasty 300 Tigrunner
Spectrum 2050
XR with ALUMA-PRO
12RC suitcase
Millermatic 251
60a feeder
Ellis 1600
Bridgeport
16" southbend
Too many Hand tools...
Originally posted by pyro2 View PostMade some aluminum ramps for a local trucker, he wanted me to test them with my welding rig
Wow, I didnt know that alluminum ramps would have the capacity for that much weight. What are they rated for, if you had to guess, besides the weight of your truck, and safe operating weight?If you want peace, be prepared for war!
I woud have to guess the capacity around 10 ton (20,000 lbs) per set... but i didn't test them untill they let go, so it's a guess... however my neighbor drove his frontloader up on them after i took my truck down and they didn't moveAttached FilesKelly
Trailblazer 301D
2 XMT 304's
Spectrum 2050
XR with ALUMA-PRO
12RC suitcase
Millermatic 251
60a feeder
Ellis 1600
Bridgeport
16" southbend
that green recumbent bike
Originally posted by Weldnut View PostI like to build recumbent bikes[IMG][/IMG]
Do you have any information, specs and measurements for me to exactly copy and build that green bike? Is this is ok with you? A full parts list would be great. This down to the gearing, seat everything if possible? Make it for a recumbent noob to understand and build.
I have a bad back so the my road bike days are gone. One recumbent I tested had the handle bar under the seat, this was all wrong in the handling department, hated it. Short wheel base is also wrong for me. Is it critical the stearing head angle and dimensions resulting from making an ok to building a great handling bike in the stability department?
Thanks in advance. PM me or email me please. If this is ok on this forum;
R90scj@alamedanet.net Thanks and have a safe holiday weekend.
Carl.....=o&o>.....Last edited by Carl W.; 11-29-2008, 03:55 AM.
Recumbent bicycle
Glad you like them .I've built seven so far,And sold a few.Just one of a few hobbys that I have.The orange bike has under the seat stearing now and the green bike was sold .I hated to see that one go .You can get all the Info on these bikes and how to make them at ://www.recycledrecumbent.com/ Have fun It's a great sight.
