I was trying to catch up a bit but some super nice stuff in this thread I certainly hadn't thought of. In the second pic the bracket started as a 1 fixture unit but got extended with a conduit coupling and additional guy wire. In the last one I use that getup for service lighting near equipment. These new CF Ls will be even easier and cheaper to operate but for near a compressor or electric panel I usually use a common 100 watt incandescent lamp.
Lets see your pics of some small projects
Originally posted by Sberry View PostI was trying to catch up a bit but some super nice stuff in this thread I certainly hadn't thought of. In the second pic the bracket started as a 1 fixture unit but got extended with a conduit coupling and additional guy wire. In the last one I use that getup for service lighting near equipment. These new CF Ls will be even easier and cheaper to operate but for near a compressor or electric panel I usually use a common 100 watt incandescent lamp.
Not haze- Low MP cameraEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Welding corner fan
This is the welding corner with the fan in the upper left.
I was fortunate enough to pick up this hood from a place that was shutting down. It went from rectangle to 12" round which just matched up with my fan. I custom made the shroud (painted red) with a removable panel on the left to get at the motor.
Fan is in the very corner and exhausts through a Dayton shutter to the outside wall. The 90 degree elbow and the round to square are standard HVAC parts.
I bought a 3 phase motor on ebay to use with a variable speed drive. This gives me control of the fan rpm, cfm, and noise level. The fan is mounted on rubber mounts to keep down vibration.
Originally posted by EdZep View PostThis is the only one I've got handy. Of course, the idea came from someone else on this forum.
That actually may just be a nut welded onto the thing...but I'd still like to know (tap and die or something)Last edited by curly; 09-18-2008, 09:13 PM.Millermatic 212
1998 Heritage Springer
Kioti DK55
Originally posted by curly View PostThat actually may just be a nut welded onto the thing...but I'd still like to know (tap and die or something)
They can get pricey so welding a nut on is cheaper fer sure.
Sometimes you have to anyway iffin' the material is not thick enough to provide enough meat for threads.Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Sometimes you have to anyway iffin' the material is not thick enough to provide enough meat for threads.Millermatic 212
Kioti DK55
Originally posted by curly View PostAnybody wanna tell me how to get the threaded hole in this. Some kinda tap thing I believe but I've never done that so don't know. Anyplace to get one reasonably priced, like harbor freight or NT? What are they called?
A decent tap and die set (typically 4-40 through 1/2") will run you a couple hundred bucks. Don't waste your money on the HF/NT garbage. These are extremely handy and worth getting a good set (HSS, not carbon steel!), as the cheap crap that breaks in the hole will cost you more than the good ones when it comes to EDM the busted one out of a valuable part.
I would never use a die to cut threads on a shaft if I had another option (often its faster and you get better threads to just cut the head off a bolt), but they do become invaluable in salvaging damaged threads.
If you don't want to plunk down the cash on a full set up front, ebay has at least one outfit that offers regrinds for cheap. The other option is to keep an eye on local machinery auctions and maybe you'll get lucky like I did. I spent $150 on a Huot 4 drawer master tap index chock full of darn near everything I would ever want, and a whole bunch more I'll probably never need. The cabinet was worth $100 - the taps are probably worth over a grand.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
Originally posted by curly View PostSo, do you find your self using them much/ever (tap and die), or usually weld the nut on?
Rough stuff I'll weld a nut on.
But on say a Finished piece like the Would Rack you wanna make, a Tap wood be usedEd Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Here's a few of mine, nothing major, and i'm waiting on the starter cart to come back from powder coat so i can get "finished pics" of it. (edit..can't find the cart pics, but the plate to hold the starter and start the bike is in here)
here's the pics (if i get the upload right hehe)
I need to find what hard-drive and folder i have the rest of my stuff in. These are some of my first projects with the new dynasty that were small and just playing around making things for myself (except the starter plate for the drag bike) Teh fuel rails are just some import car rails that were fitted with -6 AN fittings for upgraded fuel systems for E85 swaps
I'll post the new better projects as soon as i find themDynasty 200DX
Hobart Handler 135
Smith MB55A-510 O/A setup
Lathe/Mill/Bandsaw
Hypertherm Powermax 45
Just about every other hand tool you can imagine
