I am looking for some driveway gate ideas. If anyone has any they would care to share Id like to see them. Anything from basic to extensive, maybe able to merge them together in some way. Also has anyone ordered from King's metals?
Looking for some driveway gate ideas
King Metals is legit
Search Google Images "Driveway Gate" "Iron driveway gate"
you'll get some good ideas from that type of search also
http://www.google.com/search?tbm=isc...4l1138l4.5l9l0Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Here is what I did to make my two driveway gates.
A bit of a sunburst pattern made of thin wall tubing.
Each side weighs 107 lbs, so they are pretty light.
The posts are 3 inch 1/8 inch wall tubing set in A LOT of concrete.
pgDynasty 200 DX_set up on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
10 inch South Bend Lathe_3 phase
Baldor Double Cup Tool Grinder_3 phase
Baldor 10 inch Buffer
Rockwell 12 inch Disc Sander
Cyclone 2ft X 3ft Bead Blast Cabinet
Quincy 325 2stg- Air Compressor_3 phase
Graymills Built-in Parts Washer
Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
Here is a gate I did for a customer.2 inch square tube frame and 1 inch ballusters.Plasma cut decorative scene in middle.
Attached FilesLast edited by DISCONNECTED; 12-17-2011, 07:11 AM.Millermatic 210 with spoolgun
Millermatic 211
Lincoln Precision Tig 225
Miller Spectrum 375 plasma cutter
4x8 CNC Plasma Table with TD Cutmaster 101
Hydmech DM 8 horizontal bandsaw
Edwards 40 ton ironworker
Mk Morse dry cut saw
Hougen HMD 904 mag drill
2 Bench grinders
6 angle grinders
Slip roll 48 inch
Pan and box brake 48 inch
Tubing bender
etc.,etc.,etc
CNC plasma cut myself.Design is a combination of images off internet.Millermatic 210 with spoolgun
Millermatic 211
2 Bench grinders
6 angle grinders
Slip roll 48 inch
Tubing bender
etc.,etc.,etc
tmi
Originally posted by Dustin835 View PostI am looking for some driveway gate ideas. If anyone has any they would care to share Id like to see them. Anything from basic to extensive, maybe able to merge them together in some way. Also has anyone ordered from King's metals?
james, NE texasArtist Blacksmith
Historic Downtown
Paris, Texas
Dynasty 200dx
Trailblazer 302
12VS wire feeder
Lincoln 215
Miller Passport
Miller 375 plasma
Hossfeld bender
Antique SA200
here is mine ...Attached Files
