You can use cold blue for guns. It makes a nice blue finish. Wax it with Johnson paste wax in the yellow can and forget it.
David
Steel finishing
Originally posted by jtn View PostI sprayed some salt water on it and it's sitting outside . . . maybe in a few days it'll get less shiny . . .If this is what you want it can be a nice finish- just clear coat it.
If you don't have an O/A set up like Laiky's suggestion you can use a Mapp Torch, which can purchased at any Box Store or Local hardware store
I have misted some bare metal projects with a rattle can of flat black paint and when dry, lightly by hand go over with a scuff pad and then clear coat. The paint tones down the shiny areas and has a nice raw metal effect. Home Depot sells Minwax urethane clear spray cans that have UV protecters.
Sprays easily, dries fast.
there was another place posted in my to paint or not to paint posting. i'll see if i can find it for you.
oxy fuel rosebud, heat until bright red for a minute or so and let cool.
Steel finishing
Hey folks,
I'm working on some indoor coffee tables and want to give them a gunmetal/burnished look without having to dip them into a bunch of crazy hot chemicals or spray paint -- I like the look of hotrolled steel but after I grind out the junctions there's the shiny bare matel next to the dark mill scale. Any ideas? The best I've found is:
Our metal finishes, patinas and metallic coatings are safe and easy to use. They are designed to produce a wide spectrum of colors and finishes on almost any surface!
I'm working out of my garage and I'd like to keep it simple . . .
Thanks --Tags: None
