I just received the steel for the 32ft gooseneck triple axle trailer I am going to build and I have a few questions. I have repaired many trailers, and built a couple small ones, but never built a 32 footer, so is there a formula for where to place the axles exactly? I figure with three axles there should be about 16 or so ft to the beginning of the first tire, and about 8ft or so behind the last tire. But Im not sure. Also, I planned to use (4) 32ft pieces of 6"x 10.5# channel (.314 thick web) spaced 14" apart and 1/8 diamond plate runners. Does that sound strong enough? The cars weigh 3200 lbs each.
My gooseneck tongue will be 10" x 15 lb(Ithink) wide flange I beams.
Any help would be greatly appreciated,
Thanks,
Christian
Thanks,
Christian
