Engine Block
Its cast iron, not a material for the inexperienced to be attempting. If it showed up at my shop I would pass on it. No way to put a gaurantee on that.2- XMT's 350 cc/cv
1- Blue star 185
1- BOBCAT 250
1- TRAILBLAZER 302
1- MILLER DVI
2- PASSPORT PLUS
1- DYNASTY 200 DX
1- DYNASTY 280 DX
1- MAXSTAR 150 STL
1- HF-251 BOX
1- S-74D
1- S-75DXA
2- 12-RC SUITCASES
1- 8-VS SUITCASE
2- 30 A SPOOLGUNS
Originally posted by dre40 View PostOk I got this cummins engine block that has a hole in it. would you guys say that this would be able to be welded? I have the piece that was knocked out. I think its cast steel. would I be able to MIG weld it?
thanks.[ATTACH=CONFIG]28181[/ATTACH]Bob Wright
Originally posted by Portable Welder View PostI agree with fabricator ( You just cannot guarantee it )
A Metal master, The process you chose to weld it with is not as significant, Its more about proceedure, how far to weld, when to peen ETC.Bob Wright
Lock n stitch
flame spray
I have used a flame spray torch made by ESAB which is the only way I would repair cast iron. For more details on how it works you could go online and look it up. But I have had a lot of success with it. Basically it's a oxygen and acetylene torch with a built in hoper and when depress the trigger you start spraying metal which has the same properties has the cast iron base metal so it will cool at the same rate so you don't get any crakes. Its truly awesome. I know my company stocks them at www.airweld.net but you can find them all over. Good luck.
Originally posted by CSTKmauro View PostI have used a flame spray torch made by ESAB which is the only way I would repair cast iron. For more details on how it works you could go online and look it up. But I have had a lot of success with it. Basically it's a oxygen and acetylene torch with a built in hoper and when depress the trigger you start spraying metal which has the same properties has the cast iron base metal so it will cool at the same rate so you don't get any crakes. Its truly awesome. I know my company stocks them at www.airweld.net but you can find them all over. Good luck.
I believe a seemingly primal approach to this issue will suffice, I was told by a welding consultant that when working with a cast iron engine block, any rod cast metal may be used (after being heated to roughly 250°) then dipped into a granular flux, once cooled and used as a typical filler rod in the Oxy-fuel process.as far as I understood from the lecture...the preheating of both pieces is crucial for complete fusion.
Hope this is helpful!
