i found(yes found under my parents barn) a 40"x38"x1/2 peice of steel. I plan to use it for my welding table. I have used grinders,sandpaper,paint stripper you name it i have tried it. To try to get the top to be bare metal so it conducts well. Though all my efforts make the top look decent it isnt very conductive. I clamped my work lead to the metal and layed a peice of exaust pipe on the table to see how it worked and it cept arcing at the clamp and then at the bottom of the pipe and made very crappy welds. any advice? also how much would a peice of metal that size regularly cost me?
thick peice of steel for welding table
Your 1/2" plate should work fine. I always attach my work clamp to the workpiece whenever possible. In your case the tubing doesn't have much contact with the table in the first place. At least use a c clamp or vise-grip to clamp the tubing to the table.
If the surface is really pitted from rust you might want to work it over good with a hard grinding wheel and smooth out with a 50 grit sanding disc.
If you price out some new steel your going to really appreciate that free table top a lot more.
Originally posted by WB5JHYYour 1/2" plate should work fine. I always attach my work clamp to the workpiece whenever possible. In your case the tubing doesn't have much contact with the table in the first place. At least use a c clamp or vise-grip to clamp the tubing to the table.
Think outside the box
The half inch thick top is nice so keep it in place as a good find. Attach one long or two shorter grounding leads with clamps to the table. Grind just the spot you attach the cables. Then down lower on a leg grind a clean spot for your welders grounding clamp. What you will get is a strong top, close at hand grounding clamps, and the ground clamp from your welder out of your way.
