First furniture: computer game station
  • First furniture: computer game station
    I picked up this SlikStik arcade controller several years ago, on a whim. It works pretty well. But, it's too heavy to have on your lap, and, if you put it on a desk or table, the height, angles and sliding around make it uncomfortable to use. I've always wanted to make a custom setup around the controller, even though my interest in games has waned.
    Here it is, my first shot at a piece of furniture. Not bad, I think. Also my first shot at finishing wood. The frame is 1 x 1 1/2 x 14ga. retangular tubing. 1-inch angle at front and back of the controller. The wood is from a 2 x 4 foot piece of 1 1/4 inch cheap pine scrounged at Lowes for half price due to a banged up corner. My spray painting skilz are coming along, with this looking quite deep and glossy.
    MM180, and some O/A to remove some warpage. I'm still being haunted by warps where a cross-piece ties in to another that has a free end. That had caused the monitor shelf supports to droop at the 2-inch support, and had caused the front legs to be a half-inch closer at the bottom than at the top.
    Here's a bigger image
    Nice table looks really good keep on burning
      Looks good........very neat
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      Miller Syncrowave 200 Tig
      2-O/A outfits
      Jet Lathe and Mill
      Jet 7x12 horz/vert band saw
      DeWalt Multi Cutter metal saw
      Century 50 Amp Plasma Cutter
      Propane Forge
      60" X 60" router/plasma table
        Nice job on the stand. For warpage issues don't be afraid to just bend it back to where you want it. You can put a jack in between & jack it open or clamp it to something & pull on it, etc. You don't always have to straighten it with heat.
        MM250
        Trailblazer 250g
        22a feeder
        Lincoln ac/dc 225
        MM200 black face
        Lown 1/8x 36" power roller
        Arco roto-phase model M
        Vectrax 7x12 band saw
        Miller spectrum 875
        30a spoolgun w/wc-24
        RCCS-14
          very cool ......................where did you get the big video game buttons?
          Syncro250DX Tigrunner
          Victor set
          Elite auto-helmet
          Dewalt Bench grinder
          Mastercraft miter saw
          Mac air tools
          Mac hand tools
          Toothbrush
          pencil
          toilet paper
            Thanks all, for the comments.
            MMW, well, I had first tried to spread the front legs with with a jack. It sprang back, and I was afraid if I went too far I might put a crease in it. I still used the jack when I used heat -- jacked it a bit past where I wanted it, heated it, and it stayed pretty well. But, I do have another item I'll try just the jack on, and see what happens.
            Of course, I'd rather avoid the problem, if possible. I know I could weld in little bits. But, I wanted neat, continuous welds. I guess this is where TIG has an advantage over MIG.
            Dusty, I didn't make the controller, it's a unit from SlikStik. I just went looking for their website to link, and it's dead. Googled up a rumor of bankruptcy. A niche item with maybe too little demand. Yeah, those are heavy duty arcade machine joysticks and buttons.
              That is totally...
              Awesome Ed!!!
              Being a PC guy and bit of gamer, myself - That is a wicked slick arcade setup. Seeing this has me seriously thinking that I should build myself a new computer desk to my exact specs. Great work - looks great. I'd be proud!
              Best Regards,
              - Chad
              - Millermatic DVI2
              - Victor Super Range II O/A Torch
              - Milwaukee Dry Cut Chop Saw
              - Milwaukee Super Magnum 4.5" Grinder
              - Compact Bender w/ Scroll Attachment
              - Band/Ring Roller
                Nice concept, even nicer implementation. Gave me the idea to do something similar for a custom recording desk for my home recording studio. Thanks for sharing!
                Bob
                That that is is that that is not is not.
                  Chad and Bob
                  Thanks, and I'm glad I got you thinking. Yeah, there are a lot of possibilities for custom desks and work/play stations. I could really see racks full of gear for recording, or video editing, ham radio, etc.
                    Dug around a bit more. X-Arcade has the buttons for a buck each, in set of 20. X-Arcade sells controller consoles similar to mine, as well as other arcade pieces.
                    http://x-arcade.com/arcade_parts.shtml
