Hi,
I started TIG welding about three months and now that I’ve got a little bit of experience under my belt I’ve got a couple questions that I haven’t been able to find an answer to here on the forums. I’ve spent about 50 hours TIGing steel (generally .028-.095 thickness material) and about another 50 on aluminum. I apologize if these questions are overly basic or already elsewhere on the forum (I’ve done several searches but haven’t come up with much). Most of the welding I’m doing is on a Miller Syncrowave 200. I don’t have any pictures at this time, but I will try to get some. I recognize I’m asking a lot of questions with one post, but I would be more than appreciative if you could answer even just one.
1.) In regards to TIG welding steel, I’ve noticed that sometimes my bead comes out very dull grey and sometimes it comes out shiny/metallic looking, aside from the color I can usually keep all of my welds looking pretty nice and consistent. I haven’t been able to isolate any difference in my welding technique that leads to the difference. Is one better than the other? If so, what is the correct way to achieve it?
2.) Aluminum-I’ve read a lot of material on the miller site and other web sites that clearly say you should use ceriated, thoriated, etc electrodes ground to a point when welding Al on AC with an inverter based machine, however I haven’t found a clearly stated answer as to what to use on a transformer type welder such as the Syncrowave.
3.) A common problem I’ve found when I’m welding aluminum is that when I make the first tack on the piece I get some contamination around the tack no matter how well I clean the Al. After I establish the tack and lay out the bead I have no problems with contamination (unless I dip the tip
). I was thinking I’m getting this contamination because the gas doesn’t have a chance to surround the weld before the arc starts, but as far as I know the Sync doesn’t have a preflow option. Any suggestions on this?
4.) Aluminum filler rod-I was practicing one day with some .033 6061 T6 and some 4340 rod. I later found some 5356 in the shop and found I was consistently able to produce a MUCH nicer looking bead with it than the 4340. Ive spent some time on Google but I haven’t been able to find much info on when to use which type of filler rod, other than the generic “4340 is a good general purpose rod”.
5.) Most of the work I’ve been doing /practicing on is thin 6061 aluminum. I’ve been having a **** of a time preventing the thin pieces from warping when I weld them. This really becomes a problem when the pieces are at angles that are difficult/impossible to clamp and then when they warp that nice tight joint I had spreads to a very difficult to weld .125 gap. Would preheating help this problem?
I would greatly appreciate anyone’s input to these questions or any other TIG welding general advice. Thanks for you time.
