burned threw glove with tig filler
  • burned threw glove with tig filler
    i Just bought a new syncrowave 200 and im teachig my self how to tig weld. the other day i got a little to close to the tungston with the filler and it froze together. but then i got what i think was an electrical burn on my thumb that was holding the filler rod. it didnt make a mark on the gloves but made a pin hole mark on my thumb and burned like crazy..... also im getting a lot of white smoke when i tig weld... i know im not saposed to get any smoke at all so any ideas? im using unimix could that be the problem?
    What's unimix? Is that the shielding gas? Is it designed for MIG welding?
      unimix is 75% co2 and 35% argon.... the co2 is for penetration and argon is for sheilding.
        isn't 100% argon the only gas supposed to be used for TIG? Hence the name tugsten INERT gas. But there are certain applications that a mixed gas can be used hence the name GTAW ?
          i thought so to but i was told by the dealer i bought the syncrowave 200 that i can use unimix for everything but aluminum. so my thoughs are that unimix works but pure argon is better
            Get Rid of the Unimix!!
            Pure argon only, unless your going to get into the crazy helium mixes {mainly for aluminum}. Co2 is for mig welders, not tig welders. I don't mean this to sound harsh, if it's comming off that way. You will be happier with pure argon. One more thing; Watch out for the filler rod!!! i had some thing like that happen, though it fell out of my hand and went right thru my green welding coat,thru my shirt and about 1/2 into my stomach fat { it smelled like chicken , lol} .
              see thats what i dont understand about the filler... how did it burn my thumb but not the glove? i thought it was an electical burn. so yoru saying its just a heat burn? I have unimix doe my millermatic 185. i planed on getting a bottle of pure argon but the dealer said i would be ok with unimix as long as i wasnt doing aluminum.. but i wil get a bottle of argon this week. is the co2 the cause for the white smoke?
                You aren't welding on galvanized metal are you? if so that would be the white smoke ... bad stuff zinc fumes, do not breath it. If no, then I don't know what it might be, but I do agree with others that 100% argon is the way to go for tig, unless you need He added for the extra heat. Oh yeah, if unimix is 75/35 then there is an extra 10% in there somewhere. I only use C25 (75 argon/25 Co2) for mig.
                Regards, George
                  lol I think i had a typo.. unimix is 75/25 NOT 35...
                    Get some pure argon. That will do almost all TIG welding. Use a helium mix when welding aluminum at the top end of your machine's output. NEVER use a CO2 mix when TIG welding.
                    Leather welding gloves can take a lot more heat than your finger, even without showing a burn mark.
                    Try it again with the right gas and get back to us.
                      Did he know you were TIG welding with the gas? Either way, remember that if he knew how to weld, he'd be making a lot more money as a weldor than as a salesman. C-25 mix has very limited uses, just as ALL gases do. That's why there are so many gases. He's an idiot. You can tell him we said so...
                        ouch
                        somtimes if your gloves are wet high frq will l burn through(arc through) into your hand
                        smokin ana grinnin for 20 years
                        Owner MARKS MOBILE WELDING
                        trailblazer 302
                        hobart suitcase mig
                        miller 30a al spool gun
                        laramy plastic welder
                        brocco cutter
                        pipe beveler
                        all walter hand tools
                          Well i hope he knew i was tig welding... he sold me a tig welder... and you say straight argon or the 75 argon/25co2 i have 75 co2/25 argon now that i use for mig
                            100% argon for tig.
                            Regards, George
                              I didn't know if it was the same trip or not as the TIG purchase. If it wasn't, don't expect them to remember anything.
                              Like George says, 100% argon for TIG, unless you need a helium/argon mix for rare jobs.
