Well this is it, my first project. I went from, now what the heck am I going to do with thing sitin here, to Oh boy, 2 days of cutting and piecing together, there's so much to add to it, will I ever finish. :-)
looks great. throw some expanded steel sheet on there for a shelf and a drawer and its good to go.
a resize on the pic's really helps us dial up guys out.
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
Fun - What else you got to do? Been watching the weather up your way and it looks like you've been getting kicked pretty good. Hope all's well with the homestead.
Today on the weather it said the Rochester area was experiencing substantial snow and 70mph winds. Man that is one cold tropical storm!!!
Good luck.
BTW Fabtech - Good looking cart design. Especially like the milk crate.
Once you put the jug on there you'll see why the handle is in the wrong place
Your feet are going to keep hitting the wheels as you try to wheel it around.
Ed Conley http://www.screamingbroccoli.net/
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
i found handles in the front seem to work best. pull it into place and you can reach over and pull it a little closer if needed.
we got a lot of wind but no snow. the wind was bad enough to close school.
we always have a lot of wind at my house due to location, but the hole area got it this time.
thanks for the help
EdZep
I had everything cut precise, the bottom frame went together fine, it was the upper rack were I had the problem, some areas got to hot, I only knew of (I think it’s called) the pull travel, using 1 x 1 x 0.063 sq. I burned two joins, the gap was too wide. Added a lot of material to fill in the holes. I used a new direction were I push it, so now the puddle does not get to hot I’m right handed so I was welding left to right, I started right to left, worked out OK.
Broccoil1
That wasn’t a handle. LOL That’s were I was going to hang the 25’ ext cord from. I didn’t think of a handle, thanks, great input :-) I just can't stop laughing about that. That’s great.
