Originally posted by EdZep
View Post
O/A cart - something a bit different
You've never had anything fall on you? Off a shelf, off a truck, off another part you thought was clamped firmly enough...
Murphy is a real ***** when the braking force is explosive (braking as in stopping - not breaking as in broken).
Call me paranoid, but I would put a bar over your tanks to protect the valves from falling objects. Acetylene is no joke.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
Of course, I get that...
Originally posted by AnotherDano View PostSomething with "Murphy" written on it.
The first pic you posted with the gauges they were both aimed to the left. If you rotate the acetylene to the right 180, then both of them are inboard of the 4 sides. If something fell from above, it would hit your oxygen valve first.
As bad as having a 3000psi tank bust a valve off is, I would rather deal with the rocket than the big BOOM you would incur with the acetylene seeing the same fate.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Smith O/A rig
Originally posted by Fishy Jim View PostThe first pic you posted with the gauges they were both aimed to the left. If you rotate the acetylene to the right 180, then both of them are inboard of the 4 sides. If something fell from above, it would hit your oxygen valve first.
Done, and done
OK, Jim, I took your advice. Acetylene gauges are not well positioned, but can be viewed. I finally got around to doing the initial task that prompted purchase of the setup (dewarpifying the frame of another project). Thank you for the suggestion.
Originally posted by Fishy Jim View PostDo yourself a favor and rotate your acetylene tank 180 degrees to get the regulator out of the path of danger. You don't want that valve subject to anything falling on it, and right now you've added a lever.
Originally posted by AnotherDano View PostI agree BIG time..
But I've got this brother-in-law that could be a close second...Out of all the stupid things I've seen peeple do with pressure cylinders and fuel gases the guys in my shop seem to be the worst!
Nice , I think it is way over built. Just kidding , real nice work . Murphy can get you when you least expect it . Dan
Tools to Men are like Shoes to Women you can never have too many .
Miller XMT-304
Miller Spectrum 2050
Miller 10-E Feeder
Hobart 175 Handler
Lincoln AC225
And assorted others
