Electric Catamaran conversion
  • Electric Catamaran conversion
    Hay guys .. been a while since i have been here .
    I have been working on two boat projects .
    built a mini pontoon a few years back for our small no gas motor lake .. had som plastic chairs on it ..but they had to go .. I bought a pipe bender from harbor freight to play with and things got started .
    I also bought the parts to build and convert a peddle powered catamaran to elect drive .
    If it dosent have a motor i dont want it .. lol
    the catamaran is almost done .. still needs a luggage rack on the back for coolers and and such .
    the original unit had 2 peddle drive systems on the front and with them removed there was no place to put your feet or stand ,
    here are some pics of both
    enjoy Don
    Nice!!!
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
      Stupendous !
      Are these floating devices for fishing ?
      Ji
      Grip it and Rip it
        yes the intent may be to fish .. or chase girls around the lake .. lol
        I just like to think out side the box sometimes .
          It needs the umbrella or palm tree. Right?
            shade
            Some type of retractable sun shade might make a nice addition to the aluminum rig. It could be incorporated into the "luggage rack" you mentioned for the beverage cooler. That might be welcome if you've spent too many days in the sun and "Red Skin Syndrome" has set in but you still want to get out on the water. You may want to look into adding a solar battery charging system too. Northern Tools has some, this may keep you from having to remember to charge the battery after every use, and also make your battery live longer.(fewer replacements)
              I started working on the luggage rack .. need to find a bakini top from a boat thet will fit it .
              I like the idea of a solar charger ..good idea
              thanks Don
                You should be able to fabricate the frame for the top your self, then have an upholstery shop or awning company make the covering material to fit it. This may be better than trying to find one to fit such a small craft. No telling how long you may have to search to find something close to fitting since most boats with that kind of top are much wider. Hoping to find something close, may still need modifying to work and would still be a comprimise to what you actually like. An upholstery shop or awning shop could give you a choice in colors or patterns in the coverings as well. An awning co. may be able to make suggestions on how to build the frame if you check with them first. Some of them have experience making covers for boats. Cutting and bending the tubing and making mounting brackets should be pretty simple to do(after seeing what you did building those motorcycle trailers, nice work on those too). Hope this helps get you what you want sooner.
                  Let There B Shade
                  Check out this site for some ideas:
                  http://www.riversombrero.com/collections/all-products
                  Steve
                  Bobcat 250EFI
                  Millermatic 350P
                  Hypertherm 1250
                  A Bunch of tools
                  And a forklift to move the heavy stuff with..
                  Torchmate 2x2 CNC Plasma
                  It's Miller Time - Get Back To Work!
                    don,t forget to leave some room for the pink flamingos
                      Yea .. now thats what im talking about .. searched cobellas and mini paddle boats
                      there was one for a pelican paddle boat for $115.00 I was lookking at but no width dim's
                      has to be attacked to the rear deck tubes as i dont want to drill holes in the Pontoons .. another option was a reverse wale boatd tube fram with a visor .. or something like a t-top for center consel boats .
                      thanks for all the good comments .. Iplan on building a few of these To sell to folks on privat lakes that dont allow gas motors .
                      thanks Don
                        Attach the pivot points to your rear AL deck. The front and rear tie downs are in place.
                        This is my river shade and bed too:
                        Load tested to 1 fat welder, 3 fine ladies and one beer drinking lizard:
                        Your T-top has merit.. that would be a good spot to mount the solar panels..
                        Steve
                        Bobcat 250EFI
                        Millermatic 350P
                        Hypertherm 1250
                        A Bunch of tools
                          Ok i think im done working on this time sucking money pit for a bit .. time to get out in the sun and buzz around a bit .
                          i think the paddle boat top will work for width .
