Welding galvanize pipe to steel.
  • Welding galvanize pipe to steel.
    I have a project and reading on most of the dangers of galvanize welding its a blessing for me to know that i did not know the dangers untill i read about it here. I need to weld galvanize pipe to steel. I plan to use a TIG but not sure. I have a Tig/Stick Lincoln welding machine. I also have a Mig wire feed. I don't know what tipe of filler to use if i'm useing the Tig. Please help?
    Galvanized steel is still steel. It's just got a very thin zinc coating on it. You can grind it off with a flap wheel in the area you'll be welding. In any case, use a respirator and you'll be fine.
    Jack Olsen
    The Garage(And its slideshow)
    The Car(And its slideshow)
      Electrodes
      Thank you much Jack Olsen for the info. I currently have E6011,7018,and 6011. Can i use any of the electrodes that i have to weld galvanize to steel?
        All of those will work fine for stick. You mentioned you wanted to use TIG, but if you don't grind all the galvanized off it will contaminate your tungsten in a heartbeat.
        Miller Syncrowave 200
        Homemade Water Cooler
        130XP MIG
        Spectrum 375
        60 year old Logan Lathe
        Select Machine and Tool Mill
          Thank you so much guys.
          Nocheepgas, thank you for the info.
            Just grind off the galvanized where you will be welding & you can use either tig or stick.
            MM250
            Trailblazer 250g
            22a feeder
            Lincoln ac/dc 225
            MM200 black face
            Lown 1/8x 36" power roller
            Arco roto-phase model M
            Vectrax 7x12 band saw
            Miller spectrum 875
            30a spoolgun w/wc-24
            RCCS-14
              The 6011 would be the best choice.
              It is used when fencing companies make welds on galvanized fencing.
              I would not use your TIG torch. If you use your TIG torch, even though you may have ground the zinc from the surface it will pop and sputter and make a MESS out of your TIG torch. If your TIG torch has a gas lens(screen) then you can kiss that good bye because if the galvanized coating pops, small balls of metal will get stuck to the gas lens screen and when you try to strike an arc with your TIG torch in the future the arc will try to arc to the small balls of metal stuck to the gas lens screen.
              When you weld galvanized metal, drink some milk afterwards because milk will pick up metals contaminants in your body.
                I would do it as simple as I could, tig would be my last choice, 6011 if in the field, wire in the shop.
