How can u weld together two different pieces, one made of aluminum, and one made of steel or stainless steel??? Do you use AC or DC??? I'm really interested in that so please any suggestions??
Aluminum melts at half the tempurature of steel (mild or stainless) so I would be VERY surprised to find they could be fused as one. Moreover, Aluminum likes AC, but Steel likes DC.
you can solder or braze to connect different metals together. aladen has an aluminum brazing rod thats supposed to do a good job of that. but you cant just TIG them together.
steel to stainless steel is doable. but not steel and aluminum.
here is a link to them, they can send you some info on brazing aluminum to other metals. http://www.aladdin3in1.com/index.htm
i have not tryed there stuff, just read there info. so i dont know how well it works.
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.james@newyorkmetalart.com summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
It is posible to weld the two metals together. you use the same process that the makers of fancy frying pan makers do. its called explosive welding. two diffent types of metal are joined together under a controled explosion. it generates preasures of about one million psi to fuse the materials together. i wouldn't recomend trying this at home...try your neighbor's house instead...lots of info about it on the web..
