Finally built a welder cart!
  • Finally built a welder cart!
    I finally had enough of seeing my setup on an industrial cart so I decided to get off my butt and make one. I am pretty happy with the way it turned out although I am already thinking of adding some small hoops for strapping the feeder down with, and after seeing pics of it maybe a blue paint job instead of the flat black I had on the shelf. Here are some pics. Let me know what y`all think.
    Too dark to tell...
    crawler30,
    I guess it is fine. i can't really give you much feed back as the photos are too dark to see much. The black definitely does NOT cut it. Gotta go blue! Shed some light and I'll give ya some feedback.Ii am almost 50, welded most of my life, and have a hard time seeing anything without a good arc and 2.5+ cheater.
    Good Luck
    HAWK
      welding cart
      looks good to me i am curentley in the idea stage for my cart this will give me some good direction to run twards
        I am going to paint it tomorrow if I get time, the flat black did not come out the way I figured. And I have to take the power source off anyway to drill the mounting holes, I was just in a hurry to get it done and forgot about mocking up for the holes. One of my lights went out in the shop so I guess I might try to bring a camera with a flash with me to take better pics. I will try to get some of it empty too. I took those with my phone.
          First of all, the machine you have is one of the best early model inverters still in operation today. It will last you a lifetime if you take good care of it.
          The cart looks OK. Built solid & looks pretty clean. I'm with HAWK, pretty hard to make it all out due to the poor lighting.
          I would think about solid wheels in place of the rear ones you have on it now. Over time, those type of wheels tend to go flat, or get punctured. On a device such as a hand truck (where it only carries a dead load over short distances & periods of time) that's ok, just seen a lot of wheels like this crap out over time when supporting dead loads.
          The Maxtron isn't necessarily heavy, but coupled with a cylinder & the 60M feeder, it adds up.
          I have built several sets of running gear for machines & have learned that the biggest mistake a lot of people make is not using durable enough wheels. (I learned that lesson myself the hard way). After some time, they give out, leaving you to unload everything off the unit to fix the problem, at of course, the least opportune time. The front ones look ok.
          Phenolic wheels are a very good choice for moderate to heavy use running gear. They hold their shape very well, can carry & support heavy loads without distortion & hold up very well to grease, oils, etc. Ebay's the place to look for them cheap.
          I like having a little extra space on the top tray to hold welpers, chipping hammer, etc. Your cord wraps are clean & function well by the looks of it. Got one for the input power cord?
          NOT taking any shots at your work, it's looks pretty good.
          Just something to consider. I've built a few machine carts & learned what to do & not to. If you wanted some ideas for your next one, I have some pix in my album on this site. I'm no expert by far, but made a few that turned out pretty good.
          Burn some wire with that 450. It was built for it & does it very well
          So you're telling me...You're not nostalgic? Then, give me another word for it......
            The pneumatic will be getting filled with foam soon, I was going to buy some of the solid rubber ones but the cheapest I found were $55 a set. I got these for $5 at HF, for now they will have to do. The front ones are steel with a bearing (without a grease fitting) but they will last a while I think. I wanted some steel with a rubber tread but the only ones local had huge locks and I would have had to put them way outside the frame to use them. So in time they will be changed too when I can afford it or find a good deal. I am not sure what you were asking about having a tie wrap on my input cord? Do you mean a strain relief or something? I had to tie up the gas hose, feeder cord, positive cable but there is no tie on the input. I know nobody likes to have their welding cables wrapped tight but seeing as I had to wrap stick leads and keep them safe and stored til use I felt it was a good option. They are out of the way til I need them and are not just dangling off the cart so that was done by choice. I put the little bumper in the front to protect all the input/output lines from getting smashed if I accidentally bump the cart into something. All the lines run inside the frame and then up to the connections so they are not hanging all over the place. I thought about making a drawer that folds out at an angle kinda like a pocket file, and set it just above each cable on the side but I dont have any sheet metal and it can be added later if I feel like it.
            I Like the Maxtron, I have had it about 5-6 yrs now and with the amount of use it sees I hope to have it around a while longer. And yes it does run some wire and well. In fact it sticks nice too. Havent tried tig yet but eventually, just on a bit of a budget at the moment.
            Well hopefully I will have some more pics to post of the new paint job later.
              Here are the pics of the new paint and the cart empty. As soon as it dries I will add to the pile of pics. The lighting is no different but the blue sure shows up alot better. Amazing what paint can do for taking a pic. And it actually looks better too I think.Click image for larger version
ID:	511556Click image for larger version
ID:	511557Click image for larger version
                The old pix did it no justice.
                Looks really nice now that it can be completely seen.
                The cord wrap I was referring to is the same thing you wind up your lead on, just for the cord that plugs in to the wall. Didn't know if you had it directly connected to a power box or with a long cord you can connect to several outlets.
                I have been pricing the solid tires too for something I'm working on & yes, they are pricey.
                The phenolic wheels I mentioned look like the ones in the following pix. They are the rear wheels. They can be purchased as the wheel alone, these came from ebay & were quite reasonable. They are very durable. I happen to like them better than anything else I have used in the past.
                Good looking cart. Glad you posted the new pics.
                  this site still sucks
                  im not going to bring up a pic at a time
                  if miller cant up date this site im going
                  to buy lincoln
                    Much nicer pics: Great paint and lighting too! I must agree the old pics did your work no justice. I also must agree the Maxtron is a great inverter: Old but true blue. Nice completed project and fine craftsmanship as well!!!
                      to buy lincoln
                      That was actually my fault, I hit "insert in row" or something like that. I did not realize that meant it was going to post the pics like that. Oops!
                        Thanx Hawk, I guess I need to become a better photographer if I want to showcase my work, or at least make sure you can see it. HA HA, just what I need another hobby.
                        7A749, thanx. Nice carts, I like the saw cart design, thats cool. looks like a little receiver for attaching a roller stand? I like that idea, I will have to keep it in mind when I finally get a saw. One step at a time. Right now I am using a chop saw for most things and a grinder for anything the chop saw doesn`t like to cut. New set of torch bottles planed soon. thinking of going LP gas, only gotta buy one bottle that way and I only cut and heat anyway.
                        I hope to get the welder back on today so when I do I will post more pics.
                          Look forward to seeing it all done & set up. Yeah, the saw cart's square tube is for roller stands (I have yet to make). Since cutting a bunch of stuff with it, it's not so pretty anymore.
                          As I mentioned on WW, keep an eye out for a selector switch. You'll love it, makes things so easy.
                          Oh, you can use a hosting site like tinypic.com & post up the pix so they are visible without hitting on a link button. Not too difficult (I can do it )
                          Thanks for the pics!! Keep 'em coming.
                            to buy lincoln
                            Seems like a silly reason to buy Red crap.
                            Nice carts guys.
                              Originally posted by HAWK View Post
                              crawler30,
                              Good Luck
                              HAWK
                              Wait a few more years and you'll be upgrading those 2.5+ cheaters to 3.5+'s!!! and looking for shades less than 9 especially for low amp TIG.
                              Believe me I'm there!!!
                              Miller 340A/BP
                              Victor O/A torches
                              Lincoln SP125
                              Too many other tools to list
                              03 Ram 1500
                              78 GS1000
                              82 GL1100 Interstate
